How to use a Hub One as a Wi-Fi extender to a Hub Two?
John2465
Hi,  I've recently renewed my contract and have upgraded my Hub one to a Hub Two.
As I have some Wi-Fi  blackspots I was hoping to use the Hub one as an extender, but cannot find any posts on this.
Any help would be gratefully received.
Thanks,
6 REPLIES 6
Fixes: 457
Re: How to use a Hub One as a Wi-Fi extender to a Hub Two?
@John2465
Welcome to the Plusnet Community Fora.
Here are the instructions. https://community.plus.net/t5/My-Router/Using-a-2nd-Plusnet-Hub1-as-a-Wireless-Access-point/m-p/1385...
Longliner
All Star
Fixes: 8
@Baldrick1  Thanks again for all the work you must have put into these router instructions, they are really a great help to many.
John2465
Thanks; very helpful.  I'll give this a go in the next few days and report back.
John2465
Thanks for the instructions,  I have managed to get it to work after some initial difficulties.  However two things arise:
1.  The slave router has a constantly flashing red light.  How can this be stopped?
2.  When moving  through the house, devices e.g. an iPhone,  don't automatically switch between routers.
Any advice greatly received.
Fixes: 457
@John2465
1. All that you can do is apply sticky tape across the light.
2. The only certain answer is to forget extenders of any type and buy a mesh set up.
Fixes: 122
@John2465
If you are careful you can peal back the plastic cover over the flashing b light, it should stick back on (it did for me)
HTH
