How to stealth port 21 on Technicolor/Thompson Router?
ratty
Hi
I have just run the tests on grc.com and port 21, although closed, is not stealthed.  I have got Windows Firewall turned off, I'm using Comodo.  However, I think it is the router's firewall settings that need to be changed, but they seem to not be editable.  Can anyone tell me how I can stealth port 21 ftp?  I am using the Technicolor TG582n.
mattturner
Re: How to stealth port 21 on Technicolor/Thompson Router?
Hi Ratty,
Could you post the result of this telnet command from your router here?
:service system list expand=enabled
This will allow us to review the configuration of the router services and see if one is misconfigured.
Thanks,
Matt
ratty
Hi here it is.  Thanks for your help.
Regards
Ratty
{admin}=>:service system list expand=enabled
Idx Name            Protocol        SrcPort  DstPort  Group
  1 CWMP-C          tcp
        Description................ CPE Wan Management Protocol Client
        Properties................. client
        Attributes................. state srcip qoslabel routelabel
        User Managed Attributes.... state qoslabel routelabel
        Attribute Values :
        State...................... enabled{admin}=>:service system list expand=enabled
  1 CWMP-C          tcp
        Attribute Values :
        Source Ip Selection........ auto
        QOS Label.................. Management
        Route Label................ None
  2 CWMP-S          tcp                      51005
        Description................ CPE Wan Management Protocol Server
        Properties................. server
        Attributes................. state port aclip aclif aclifgroup map log qoslabel routelabel natpmweight
        User Managed Attributes.... state port log natpmweight
        Attribute Values :
        Port....................... 51005
        QOS Label.................. None
        NAT Portmap Weight ........ 30
        Ip Access List............. any
        Interface Access List...... any
        Interface Group Access List any
        Map List................... 51005
        Logging.................... disabled
  3 DHCP-S          udp                      676
        Description................ DHCP Server
        User Managed Attributes.... state log natpmweight
        Attribute Values :
        Port....................... 676
        Interface Access List...... LocalNetwork
        Map List................... 676
  4 DNS-C            udp                      53
        Description................ DNS Client
        Attributes................. state port srcip qoslabel routelabel
        User Managed Attributes.... state srcip
        Attribute Values :
        Port....................... 53
  5 DNS-S            udp                      53
        Description................ DNS Server
        Properties................. relay
        Attributes................. state port srcip aclip aclif aclifgroup map log forward qoslabel routelabel natpmweight
        User Managed Attributes.... state srcip aclip aclif aclifgroup map log natpmweight
        Attribute Values :
        Interface Group Access List lan
        Map List................... 53
        Forwarding................. enabled
  6 DYNAMIC_DNS
        Description................ Dynamic DNS
        Properties................. group
        Attributes................. state srcip aclip aclif aclifgroup map log forward qoslabel routelabel natpmweight
        Attribute Values :
        Map List................... none
  7 FTP              tcp                      21
        Description................ File Transfer
        User Managed Attributes.... state port aclip aclif aclifgroup map log natpmweight
        Attribute Values :
        Port....................... 21
        Map List................... 21
  8 HTTP            tcp                      80
        Description................ HTTP web server
        User Managed Attributes.... state aclip aclif aclifgroup map log natpmweight
        Attribute Values :
        Port....................... 80
        Map List................... 80
  9 HTTPI            tcp                      8080
        Description................ HTTP intercept proxy
        Properties................. proxy
        User Managed Attributes.... map log natpmweight
        Attribute Values :
        State...................... (administratively) disabled
        Port....................... 8080
        Map List................... 80:LocalNetwork 1080:LocalNetwork 8080:LocalNetwork
10 HTTPs            tcp                      443
        Description................ HTTP web server over ssl
        Attribute Values :
        Port....................... 443
        Map List................... 443
11 IGMP-Proxy      igmp
        Description................ IGMP based multicast forwarding
        Attributes................. state aclip aclif aclifgroup map log qoslabel routelabel natpmweight
        Attribute Values :
        Map List................... any interface group
12 IP_COMMANDS
        Description................ IP connectivity commands
        Attribute Values :
13 MDAP            udp                      3235
        Description................ Setup and upgrade wizard support
        Attribute Values :
        Port....................... 3235
        Map List................... 3235
14 PING_RESPONDER  icmp                      8
        Description................ ICMP echo responder
        User Managed Attributes.... state aclip aclif aclifgroup log natpmweight
        Attribute Values :
15 PPTP
        Description................ PPTP VPN
        Attribute Values :
16 Remote-MBus      tcp                      2006
        Description................ MBus daemon connection using INET sockets
        Attribute Values :
        Port....................... 2006
        Map List................... 2006
17 RIP              udp              520      520
        Description................ Routing Information Protocol
        Properties................. peer group
        Attributes................. state port srcip aclip aclif aclifgroup map log qoslabel routelabel natpmweight
        Attribute Values :
        Port....................... 520
        Map List................... 520
18 SLA_ICMP_PING    icmp                      8
        Description................ Ping using ICMP for SLA purposes
        Attribute Values :
19 SLA_UDP_PING    udp                      7
        Description................ Ping using UDP for SLA purposes
        Attribute Values :
        Port....................... 7
20 SNTP            udp              123      123
        Description................ Simple Network Time Protocol
        Attribute Values :
        Port....................... 123
21 SSDP            udp                      1900
        Description................ Simple Service Discovery Protocol (UPnP)
        Attribute Values :
        Port....................... 1900
        Map List................... 1900
22 SYSLOG          udp                      514
        Description................ System Logging Events
        Attribute Values :
        Port....................... 514
23 TELNET          tcp                      23
        Description................ Virtual Terminal
        Attribute Values :
        Port....................... 23
        Map List................... 23
24 WEBF            tcp                      80
        Description................ HTTP intercept web filter
        Attribute Values :
25 webservice      tcp                      9000
        Description................ WebService API
        Attribute Values :
        Port....................... 9000
        Map List................... 9000
{admin}=>
  2 CWMP-S          tcp                      51005
        Attribute Values :
  3 DHCP-S          udp                      676
        Attribute Values :
  4 DNS-C            udp                      53
        Attribute Values :
  5 DNS-S            udp                      53
        Attribute Values :
  6 DYNAMIC_DNS
        Attribute Values :
  7 FTP              tcp                      21
        Attribute Values :
  8 HTTP            tcp                      80
        Attribute Values :
  9 HTTPI            tcp                      8080
        Attribute Values :
10 HTTPs            tcp                      443
        Attribute Values :
11 IGMP-Proxy      igmp
        Attribute Values :
12 IP_COMMANDS
        Attribute Values :
13 MDAP            udp                      3235
        Attribute Values :
        Attribute Values :
15 PPTP
        Attribute Values :
        Attribute Values :
17 RIP              udp              520      520
        Attribute Values :
        Attribute Values :
        Attribute Values :
20 SNTP            udp              123      123
        Attribute Values :
21 SSDP            udp                      1900
        Attribute Values :
22 SYSLOG          udp                      514
        Attribute Values :
23 TELNET          tcp                      23
        Attribute Values :
24 WEBF            tcp                      80
        Attribute Values :
        Attribute Values :
{admin}=>
mattturner
Hi Ratty,
This command will disable the FTP server on the router. I'm not sure why the FTP server is sending TCP reset packets to request from the WAN interface (assuming this is what it is doing...), I've got the FTP server enabled on my TG582n (but just on the LAN interface as yours is) and the packets are dropped silently.
:service system modify name=FTP state=disabled
Let me know if this fixes the issue.
Thanks,
Matt
ratty
Hi
Thanks for your help so far.  I tried your suggestion, but grc.com still reports FTP port 21 as closed but not stealthed.
Regards
ratty
ratty
Hi
In telnet, :service host list gives the result FTP Server host = 192.168.1.253 Server.
What would be the security and useability ramifications of typing
:service host disable name="FTP Server"
Thanks for your time and help so far.
Regards
Ratty
ratty
Hi
This has stealthed the port, but I'd like to be sure that it is the correct command to put in to do this securely.
Thanks.
ratty
mattturner
Hi Ratty,
Service Host is where port forwarding rules are set up. It looks like port 21 is forwarded from the WAN IP to LAN IP 192.168.1.253.
I'll check with Technicolor and see why this is.
Thanks,
Matt
mattturner
OK, we know why it was forwarded, it is for the FTP functionality of the file server from the USB port.
The command you ran will probably prevent this from being accessible on the WAN if you ever chose to set it up.
You've fully disabled it with the command you ran.
Thanks,
Matt
ratty
Okay.  Thanks for all of your help.
Regards
Ratty
