How to replace router?
- How to replace router?
23-07-2014 2:46 PM
Sorry if this is a real noob question but I don't really know much about networking and I haven't been able to find the answer from here or from the support site.
I want to replace the Technicolor router that came with my fibre connection with a gigiabit wifi router, probably the R6250. How do I actually go about doing this? Do I just plug the OpenReach modem into the router by the ethernet cable and I'm away or is there anything else I need to be aware of?
Just want to make sure my bases are covered before I take the plunge!
Message 1 of 5
(1,193 Views)
4 REPLIES 4
Re: How to replace router?
23-07-2014 2:48 PM
Hi andersll,
Welcome to the Forums
What's the make and model of the router?
Message 2 of 5
(713 Views)
23-07-2014 2:49 PM
Hi Chris, thanks!
I was looking to get the Netgear R6250: http://www.netgear.co.uk/home/products/networking/wifi-routers/R6250.aspx
Message 3 of 5
(713 Views)
23-07-2014 2:53 PM
All you'll need to do is connect the router up to the Openreach Modem as your current router is already.
When you go through the router setup, a couple of important things you'll need:
Username and Password to authenticate your account details through your new router.
The username will be:
Username: username@plusdsl.net - the first part of this would be the account username you use to log into your Member Centre
Password: Your Plusnet account password
I hope this helps
I hope this helps
Message 4 of 5
(713 Views)
23-07-2014 3:05 PM
Awesome, thanks Chris!
Message 5 of 5
(713 Views)
