How to remove errors registered on my line
- How to remove errors registered on my line
Re: How to remove errors registered on my line
17-06-2012 12:36 AM
Select the main Noise Margin tab. In the bottom LH corner there is a check box which needs checking to plot the graph. Make sure it is checked on both the Downsream and Upstream tabs. Do the same on the Sync speed tab for Downstream and Upstream.
Whilst you are on each of those graphs, do a right click whilst the cursor is in the graph area. You should see Scheduled capture ticked and further down the list, put a tick against Include in Log.
Go back to the Noise Margin tab and click on the Green arrow key and it should start.
17-06-2012 12:42 AM
17-06-2012 12:58 AM
17-06-2012 1:02 AM
17-06-2012 1:07 AM
17-06-2012 1:13 AM
17-06-2012 1:16 AM
17-06-2012 1:22 AM
Edit: I don't think it will, there will be some vital settings missing. depending on how you are for time there are 2 ways of doing this.
17-06-2012 1:27 AM
17-06-2012 1:33 AM
17-06-2012 12:14 PM
17-06-2012 1:58 PM
In that folder you should now find another folder called OtherRouters. In that folder you will find a file called Billion7800N.ini .Copy (not move) it up to the C:\RouterStats68 folder. Now, if you already have a RouterStats.ini file in this folder rename it to rubbish.ini or delete it, then rename this copy of Billion7800N.ini to RouterStats.ini. You should also have created a shortcut to RouterStats.exe on your Desktop.
The other folder you should have created, I suggested in My Documents or on your Desktop was one called just plain Routerstats. This is the folder where the Graphs and log files will get saved, and the one that you browse to when setting up the Log file and the Capture folder. If it's confusing you with similar names, call it something else such as RScapture if you like. Just remember to Browse to that folder for the Log File and the Graphs Capture folder.
If you now continue the setup from the words ...."Now we have some setting up to do" in the second paragraph, and follow through the next few posts following.
If that's still confusing post back telling me the point at which you are confused and I'll try and clarify. It's all a bit hairy to start with, but don't worry about it.
17-06-2012 2:58 PM
17-06-2012 3:19 PM
Then got to the plain Routerstats folder or RScapture which ever you called it, you should see the .jpg files of the capture. You should also see the RSlog2012-6-17.txt file (today's) which should be recording data. Post the 2 .jpg's and the top page (using copy and paste into a post) of the RSlog, just so I can see it's recording correctly.
We'll see what that's all looking like before doing any more.
You know how to attach files to a post?
17-06-2012 3:35 PM
Sun 17 Jun 2012 14:57:48, 9.4, 26.2, 9955, 443, 32.0, 17.8,
Sun 17 Jun 2012 14:57:57, 9.4, 25.8, 9955, 443, 32.0, 17.8,
Sun 17 Jun 2012 14:58:04, 9.4, 25.8, 9955, 443, 32.0, 17.8,
Sun 17 Jun 2012 14:58:12, 9.4, 25.8, 9955, 443, 32.0, 17.8,
Sun 17 Jun 2012 14:58:21, 9.4, 26.0, 9955, 443, 32.0, 17.8,
Sun 17 Jun 2012 14:58:28, 9.4, 26.0, 9955, 443, 32.0, 17.8,
Sun 17 Jun 2012 14:58:36, 9.4, 25.6, 9955, 443, 32.0, 17.8,
Sun 17 Jun 2012 14:58:51, 9.4, 25.6, 9955, 443, 32.0, 17.8,
Sun 17 Jun 2012 14:59:01, 9.5, 25.6, 9955, 443, 32.0, 17.8,
Sun 17 Jun 2012 14:59:09, 9.5, 26.1, 9955, 443, 32.0, 17.8,
