How to remove errors registered on my line
- How to remove errors registered on my line
16-06-2012 1:16 PM
Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 17.8 32.0
SNR Margin: 18 10
Errored Seconds: 0 1
HEC Errors: 0
Cell Count: 3043737 12196625
Speed: 443 11647
Maximum Stable Rate (KBPS): 11360 Fault Threshold Rate (KBPS): 9088
Mean Time Between Retrains (Seconds): 86400 Mean Time Between Errors Upstream (Seconds): 86400
Indicative Line Quality: A Mean Time Between Errors Downstream (Seconds): 114
Re: How to remove errors registered on my line
16-06-2012 1:29 PM
Interleaving would be what is affecting your latency which can be nasty for gaming
Does your router stats included the corrected and uncorrected errors as the corrected errors are the ones we are interested in. This is because with interleaving switched off they would then be uncorrected errors
16-06-2012 1:50 PM
I believe my line does not have interleaving on it. As for the corrected errors I'm not too sure how I can check this with my Billion 7800n.
This is what I got back from plusnet..
It looks like the issue is being caused by errors being registered on your line (confirmed by our supplier's tests). The information being sent 'to' you is getting corrupted and having to be 'resent' which is causing speed reductions and high ping / ms times.
Our suppliers have applied a technology called 'Interleaving' which is a form of error correction but this does not seem to be able to correct the problem.
16-06-2012 1:55 PM
This thread explains how to get the information
http://forums.thinkbroadband.com/dslrouter/4094211-billion-7800n-line-stats-errors.html
16-06-2012 2:04 PM
The first is to plug the router into the test socket to isolate the house wiring and see what the errors are like after 24 hours
The next thing is to turn on impulse noise protection and check again after 24 hours
Finally if that doesn't solve the problem, use the default noise margin tweaking capability with the Billion to push the default nioise margin up to 15dB (it looks as though it is 9dB at present. This will reduce the sync speed but given the speeds you are getting at present that won't mess up your gaming
This explains it http://www.increasebroadbandspeed.co.uk/billion-7800n and here http://forums.whirlpool.net.au/archive/1567481 for the values to increase the default noise margin
16-06-2012 2:08 PM
What version (hardware and firmware) is your Billion 7800n?
If your ping bbc.co.uk also ntp.plus.net, both from a command prompt what results do you get?
16-06-2012 2:33 PM
Current Time Sat Jun 16 13:23:36 2012
Hardware Version Annex A
Software Version 1.06g
Pinging bbc.co.uk [212.58.241.131] with 32 bytes of data:
Reply from 212.58.241.131: bytes=32 time=36ms TTL=245
Reply from 212.58.241.131: bytes=32 time=35ms TTL=245
Ping statistics for 212.58.241.131:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 35ms, Maximum = 36ms, Average = 35ms
Pinging ntp.plus.net [212.159.6.9] with 32 bytes of data:
Reply from 212.159.6.9: bytes=32 time=37ms TTL=251
Reply from 212.159.6.9: bytes=32 time=36ms TTL=251
Reply from 212.159.6.9: bytes=32 time=35ms TTL=251
Ping statistics for 212.159.6.9:
Minimum = 35ms, Maximum = 37ms, Average = 36ms
16-06-2012 2:37 PM
16-06-2012 3:27 PM
Once you have logged in type adsl info --stats and hit return. When the results are on the screen you have to copy and paste into a post. Do do this, right click on the results and select Mark. Now move the cursor to the start of the area you want to copy and hold down the left mouse key and drag the cursor to the bottom of the RH corner of the area to copy so that all the area is highlighted, then release the left key. Then do 1 right click and don't click anything else until you are at the post reply box.
Then right click and select Paste.
Repeat the above for adsl info --show
HTH.
16-06-2012 4:00 PM
adsl: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 8000
Max: Upstream rate = 1128 Kbps, Downstream rate = 13120 Kbps
Path: 0, Upstream rate = 443 Kbps, Downstream rate = 10527 Kbps
Link Power State: L0
Mode: ADSL2+
TPS-TC: ATM Mode
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 9.2 28.0
Attn(dB): 32.0 17.9
Pwr(dBm): 0.0 12.9
ADSL2 framing
MSGc: 51 12
B: 187 13
M: 1 1
T: 2 4
R: 0 0
S: 0.5699 0.9911
L: 2639 113
😧 1 1
Counters
SF: 292702 266428
SFErr: 64 0
RS: 0 0
RSCorr: 0 0
RSUnCorr: 0 0
HEC: 39 0
OCD: 2 0
LCD: 0 0
Total Cells: 118047451 4961531
Data Cells: 2902369 578057
Drop Cells: 9374
Bit Errors: 0 0
ES: 8735 809
SES: 151 1
UAS: 203 203
AS: 4754
INP: 0.00 0.00
PER: 16.24 17.84
delay: 0.14 0.24
OR: 28.07 8.07
Bitswap: 255 112
Total time = 1 days 22 hours 9 min 52 sec
FEC: 0 0
CRC: 18103 0
ES: 8735 809
SES: 151 1
UAS: 203 203
LOS: 4 0
LOF: 36 0
Latest 15 minutes time = 9 min 52 sec
FEC: 0 0
CRC: 6 0
ES: 6 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 0 0
CRC: 7 0
ES: 7 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Latest 1 day time = 22 hours 9 min 52 sec
FEC: 0 0
CRC: 1572 0
ES: 713 209
SES: 15 0
UAS: 68 68
LOS: 1 0
LOF: 9 0
Previous 1 day time = 24 hours 0 sec
FEC: 0 0
CRC: 1656 0
ES: 675 339
SES: 18 1
UAS: 0 0
LOS: 0 0
LOF: 0 0
Since Link time = 1 hours 19 min 13 sec
FEC: 0 0
CRC: 64 0
ES: 49 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Status: Showtime
Max: Upstream rate = 1132 Kbps, Downstream rate = 13120 Kbps
Mode: ADSL2+
TPS-TC: ATM Mode
Trellis: U:ON /D:ON
Down Up
SNR (dB): 9.2 28.2
Attn(dB): 32.0 17.9
Pwr(dBm): 0.0 12.9
ADSL2 framing
MSGc: 51 12
B: 187 13
M: 1 1
T: 2 4
R: 0 0
S: 0.5699 0.9911
L: 2639 113
😧 1 1
Counters
SF: 308448 280781
SFErr: 66 0
RS: 0 0
RSCorr: 0 0
RSUnCorr: 0 0
HEC: 40 0
OCD: 2 0
LCD: 0 0
Total Cells: 124398644 5227092
Data Cells: 2993528 600629
Drop Cells: 9374
Bit Errors: 0 0
ES: 8737 809
SES: 151 1
UAS: 203 203
AS: 5010
INP: 0.00 0.00
PER: 16.24 17.84
delay: 0.14 0.24
OR: 28.07 8.07
Bitswap: 272 119
16-06-2012 4:39 PM
When you use your phone, can you hear any crackling or other noises on the line? Can you listen to your phone line as soon as convenient?
16-06-2012 4:44 PM
Edit: I presume there is an open ticket on a fault at the moment? If you could post the ticket number with one of your posts.
16-06-2012 4:58 PM
There is no crackling or weird noises on my phone line.
I don't have any open tickets and the last one was 14th June where they said;
"It looks like the issue is being caused by errors being registered on your line (confirmed by our supplier's tests). The information being sent 'to' you is getting corrupted and having to be 'resent' which is causing speed reductions and high ping / ms times.
Our suppliers have applied a technology called 'Interleaving' which is a form of error correction but this does not seem to be able to correct the problem."
16-06-2012 5:14 PM
Also just for future reference do you have a spare modem/router and during any of your fault reports have you been asked and have you tried another filter? Again, don't rush to change anything yet.
16-06-2012 5:15 PM
Note that even with a capped upstream of 443kbps and a noise margin of 28dB you are still getting upstream error seconds and the downstream is also bad - about 700 error seconds in 24 hours
Do you have a master socket with a removable lower plate and a test socket behind it
Note to avoid confusion I will duck out of this thread for a while and leave you and Anotherone to discuss things
