How to remove a static IP address
Wimpywoo
Hi , for some reason I can't remove a static ip please could someone explain why I would be getting a static ip on a residential line ? Thank you.
Fixes: 62
Re: How to remove a static IP address
I don't think that you have
If you disconnect and then reconnect via the router interface (not a line resync) does it change
Wimpywoo
Thank you for replying but that's what's came up when checking my IP address.
Fixes: 210
You don't have a static IP address with ourselves at the moment.
Each time you disconnect and reconnect you'll get a different one.
 Matthew Wheeler
Wimpywoo
But that's different to what the screenshot is displaying after checking my ip, thanks for you reply.
Fixes: 62
So how does that site know  whether it is fixed or not
Wimpywoo
I don't know , I suppose you could same the same about all the sites , for example the gateway checker/ broadband speed test, you would have to ask them. Thank you for your reply. Here's the link to the site. http://whatismyipaddress.com and this is what I got from a reliable site.
Your IP Address Is:87.112.188.171Proxy: No Proxy DetectedCity: PoolState/Region: EnglandCountry: Gb - gb flagPostal Code: S1 2guTime Zone: ETC +01:00ISP: Plusnet Plc.
Latitude: 50.21667098999 Longitude: -5.2833299636841
Map data ©2015 Google
Terms of Use
Map
  % This is the RIPE Database query service.
% The objects are in RPSL format.
% The RIPE Database is subject to Terms and Conditions.
% See http://www.ripe.net/db/support/db-terms-conditions.pdf
% Note: this output has been filtered.
%      To receive output for a database update, use the "-B" flag.
% Information related to '87.112.0.0 - 87.112.199.255'
% Abuse contact for '87.112.0.0 - 87.112.199.255' is 'abuse@plus.net'
inetnum:        87.112.0.0 - 87.112.199.255
netname:        PLUSNET-DIAL-ADSL
descr:          Dial-up and ADSL pool
descr:          Plusnet plc
country:        GB
admin-c:        PLUS1-RIPE
tech-c:        PNET2-RIPE
status:        ASSIGNED PA
mnt-by:        MAINT-AS6871
source:        RIPE # Filtered
role:          Plusnet Hostmaster
address:        PlusNet Plc
address:        The Balance
address:        2 Pinfold Street
address:        Sheffield
address:        S1 2GU
address:        UK
phone:          +44 114 2200084
abuse-mailbox:  abuse@plus.net
remarks:        ------------------------------------------------
remarks:        Please do NOT e-mail abuse to the contacts given
remarks:        here, e-mail them to ABUSE@PLUS.NET instead.
remarks:        All email sent to other listed addresses will
remarks:        be deleted!
remarks:        Network Status and Information Page:
remarks:        http://status.plus.net
remarks:        http://support.plus.net
remarks:        Support 24*7 Phone: (UK) 0845 140 0200
admin-c:        SB195-RIPE
tech-c:        DS3916-RIPE
tech-c:        RM6084-RIPE
nic-hdl:        PNET2-RIPE
person:        PlusNet Ripe Admin
address:        Plusnet plc.
address:        Sheffield
address:        S1 2GU
address:        GB
phone:          +44 114 22 00084
nic-hdl:        PLUS1-RIPE
% Information related to '87.112.0.0/16AS6871'
route:          87.112.0.0/16
descr:          PlusNet plc.
origin:        AS6871
% This query was served by the RIPE Database Query Service version 1.79.1 (DB-3)
JayG
Have you tried gateway hopping as per Oldjim's earlier post to see if it changes? You may have to do it more than once to be absolutely sure.
Wimpywoo
Hi, no I haven't done that because I wouldn't know how to, but I did go onto another site and checked my ip, thanks for your reply.
Server & Network Information
Hostname: 171.188.112.87.dyn.plus.net
Proxy: No Proxy or Invisible Proxy Used
SCRIPT_URL: /more-info-about-you/
SCRIPT_URI: http://www.whatsmyip.org/more-info-about-you/
HTTP_HOST: www.whatsmyip.org
HTTP_REFERER: http://www.whatsmyip.org/
HTTP_ACCEPT_ENCODING: gzip, deflate
HTTP_ACCEPT: text/html, application/xhtml+xml, application/xml;q=0.9, */*;q=0.8
HTTP_ACCEPT_LANGUAGE: en-us
HTTP_CONNECTION: keep-alive
HTTP_USER_AGENT: Mozilla/5.0 (iPhone; CPU iPhone OS 8_3 like Mac OS X) AppleWebKit/600.1.4 (KHTML, like Gecko) Version/8.0 Mobile/12F70 Safari/600.1.4
SERVER_SIGNATURE: <address>Apache/2.2.24 (Unix) DAV/2 mod_fastcgi/2.4.2 mod_ssl/2.2.24 OpenSSL/0.9.8y Server at www.whatsmyip.org Port 80</address>
SERVER_SOFTWARE: Apache/2.2.24 (Unix) DAV/2 mod_fastcgi/2.4.2 mod_ssl/2.2.24 OpenSSL/0.9.8y
SERVER_NAME: www.whatsmyip.org
SERVER_ADDR: 208.64.38.55
SERVER_PORT: 80
REMOTE_PORT: 51540
GATEWAY_INTERFACE: CGI/1.1
SERVER_PROTOCOL: HTTP/1.1
REQUEST_METHOD: GET
QUERY_STRING:
REQUEST_URI: /more-info-about-you/
SCRIPT_NAME: /more-info-about-you/index.php
PHP_SELF: /more-info-about-you/index.php
REQUEST_TIME: 1430757034 (Mon, 04 May 2015 12:30:34 -0400)
Browser Information
Refered From: http://www.whatsmyip.org/
User Agent: Mozilla/5.0 (iPhone; CPU iPhone OS 8_3 like Mac OS X) AppleWebKit/600.1.4 (KHTML, like Gecko) Version/8.0 Mobile/12F70 Safari/600.1.4
Screen Resolution: 320 x 568 (pixels)
Browser Dimensions: 763 x 1260 (pixels)
Cookie Status: Enabled
Cookies (Only Cookies Visible to WhatsMyIP.org): none
Browser Plugins: No Plugins Installed
WHOIS Lookup On You
# ARIN WHOIS data and services are subject to the Terms of Use
# available at: https://www.arin.net/whois_tou.html
# If you see inaccuracies in the results, please report at
# http://www.arin.net/public/whoisinaccuracy/index.xhtml
# The following results may also be obtained via:
# http://whois.arin.net/rest/nets;q=87.112.188.171?showDetails=true&showARIN=false&showNonArinTopLevel...
NetRange: 87.0.0.0 - 87.255.255.255
CIDR: 87.0.0.0/8
NetName: 87-RIPE
NetHandle: NET-87-0-0-0-1
Parent: ()
NetType: Allocated to RIPE NCC
OriginAS:
Organization: RIPE Network Coordination Centre (RIPE)
RegDate: 2004-04-01
Updated: 2009-05-18
Comment: These addresses have been further assigned to users in
Comment: the RIPE NCC region. Contact information can be found in
Comment: the RIPE database at http://www.ripe.net/whois
Ref: http://whois.arin.net/rest/net/NET-87-0-0-0-1
OrgName: RIPE Network Coordination Centre
OrgId: RIPE
Address: P.O. Box 10096
City: Amsterdam
StateProv:
PostalCode: 1001EB
Country: NL
RegDate:
Updated: 2013-07-29
Ref: http://whois.arin.net/rest/org/RIPE
OrgTechHandle: RNO29-ARIN
OrgTechName: RIPE NCC Operations
OrgTechPhone: +31 20 535 4444
OrgTechEmail: hostmaster@ripe.net
OrgTechRef: http://whois.arin.net/rest/poc/RNO29-ARIN
OrgAbuseHandle: ABUSE3850-ARIN
OrgAbuseName: Abuse Contact
OrgAbusePhone: +31205354444
OrgAbuseEmail: abuse@ripe.net
OrgAbuseRef: http://whois.arin.net/rest/poc/ABUSE3850-ARIN
itsme
They may be an very few customers that truly have static IP's, these are the ones that request a block of addresses. The rest will have dynamic IP's even the ones that believe they have static.
If you look at the ripe query you will see
status:         ASSIGNED PA
this to the world would mean that the address has been allocated as dynamic. I have a static IP from Plusnet but to the outside world this still look as Dynamic as it's ASSIGNED PA. A true static IP you will see
status:         ASSIGNED PI
Wimpywoo
Thank you , so the site whatsmyipaddress isn't giving out proper information then? Thank you for your reply.
Fixes: 5
Every time you've established a new connection, you've had a different IP. Your current connection has been ongoing for most of the day though. How exactly are you disconnecting?
 Tony T
Wimpywoo
Hi, thank you for your reply, I'm not disconnecting?
Fixes: 67
Website whatsmyipaddress is giving out correct information. This is the details for your current IP address which Plusnet staff have confirmed is a dynamic one. A dynamic address doesn't change minute-by-minute, it changes only when your internet connection to Plusnet is disconnected, then re-established. A connection can last for several days, even weeks.
Do you switch the router off at night then on again in the morning? That will cause your IP address to change - though for best performance it is best to leave the router permanently on.
David
David
Wimpywoo
Thank you for you reply, So I have got a static ip then? And no I do not turn my router of at night, and it doesn't matter what I do this static ip has been like this since I can remember, (even with other ISP providers) we have stolen emails (compromised) we have had loads and loads of problems, in all the time we moved into this house eight or nine years ago, the problems we've had is endless, just don't know why or what it is? P.s I think it's finally fixed it's now a dynamic IP address.... For a day I expect Smiley but thanks all for your help. Much appreciated.
