How to open nat on a netgear router for pc gaming
rodtrotter
How the hell do I open the nat for pc gaming with a netgear router
Fixes: 62
Re: How to open nat on a netgear router for pc gaming
which router as on a number of them you apparently can't
Hi rodtrotter,
There's a guide on the portforward.com website for each router, you'll probably find yours on there: http://portforward.com/english/routers/port_forwarding/routerindex.htm
You can also check which ports need to be forwarded on their applications list: http://portforward.com/cports.htm
Hope that helps,
rodtrotter
seem to have got it sorted i fond the only way to open the nat was to turn upnp on in the router settings how need to do some stat tests on the test socket
