How to open nat on a netgear router for pc gaming
- Re: How to open nat on a netgear router for pc gam...
10-11-2011 1:15 PM
How the hell do I open the nat for pc gaming with a netgear router
Message 1 of 4
(772 Views)
3 REPLIES 3
Re: How to open nat on a netgear router for pc gaming
10-11-2011 1:41 PM
which router as on a number of them you apparently can't
Message 2 of 4
(434 Views)
10-11-2011 3:20 PM
Hi rodtrotter,
There's a guide on the portforward.com website for each router, you'll probably find yours on there: http://portforward.com/english/routers/port_forwarding/routerindex.htm
You can also check which ports need to be forwarded on their applications list: http://portforward.com/cports.htm
Hope that helps,
Hope that helps,
Message 3 of 4
(434 Views)
11-11-2011 3:06 PM
seem to have got it sorted i fond the only way to open the nat was to turn upnp on in the router settings how need to do some stat tests on the test socket
Message 4 of 4
(434 Views)
