How to improve sync speed?
- How to improve sync speed?
Re: How to improve sync speed?
05-11-2009 11:37 AM
However I would leave it connected continuously and if, after about 3 weeks, it hasn't changed raise a ticket explaining what you have done and that the line has been stable for 3 weeks and ask that the default noise margin should be lowered to 6dB.
05-11-2009 12:01 PM
just a thought as it rules out any cables issues from the socket to your router and looks neat as well. it also points any faults to the bit bt has to look after, ie outside your house, unless your router or pc are shot.
they do shorter lengths as well.
http://www.adslnation.com/phpapps/catalog/product_info.php?cPath=21&products_id=118
just my 2p's worth
regards
Andy
05-11-2009 6:52 PM
Results after 2 days of using ADSLNation faceplate. Router was rebooted last night after a 10sec electrical powercut.
3/11 4/11 5/11
Download speed 1040kps 956kps 1098kps
DSL Conn rate Down 1856kps 3872kps 3808kps
UP 448kps 448kps 448kps
IP Profile 1500kps 3000kps 3000kps
Router up time 21 hrs
SN Margin (Down) 14.5db
Martin2006 - I would love to have something nearer to 6K like you. As you can see I am struggling to get 1k. I am using the cable supplied with the D-Link router so I assumed that it is a quality cable and so did not think I need to replace it as part of my attempt at getting faster speed. I think the BT cable to the master socket is okay as PN ran tests with router connected to the test socket and said the problem was in my internal wiring or telephones and I should be getting a 4 speed increase if I removed the problem.
Oldjim - I am still learning about SN margin. From looking at the router stats I can see the SN margin and it changes frequently on its own. Until your reply I had not realised that this could be set by PN. I will wait patiently for 3 weeks with fingers crossed that the router stays up for that time. So far the router has been rebooted each day for different reasons.
Regards.
05-11-2009 9:21 PM
are you a long way from your exchange to be getting those speeds or just in the process of getting sorted
it does seem to taKe an age for things to update though
05-11-2009 10:12 PM
05-11-2009 11:27 PM
http://www.top10-broadband.co.uk/packages/
click on tools for the one above and enter postcode
http://www.top10-broadband.co.uk/speedtest/streetstats/
these might be helpful although you cant always believe everything
one site said if you dial 170170 from a bt phone it calculates the length of your line to the exchange but i have no idea if that works, might make your head drop off for all i know
hope you get it sorted though as i know it can be really frustrating
its all a process of elimination, find out what you should get, what others around you are getting and then rule out one thing at a time.
Re:How to improve sync speed?
06-11-2009 3:44 PM
Looking at your post here your sync speed has increased from 1856kps on the 3rd to 3808kps on the 4th and 5th. Your IP profile at the time you posted was still set to 1000kbps but it looks like that's now increased to 3000kbps
Whilst your SNR is at 15db you'll not get the most out of your line but if things remain stable for a few weeks then there's a possibility that we'll be able to get this reset for you.
Dropping it to 6db will probably increase your sync speed to something in the region of 6500kbps.
06-11-2009 8:45 PM
3/11 4/11 5/11 6/11
Download speed 1040kps 956kps 1098kps 1164kps
DSL Conn rate Down 1856kps 3872kps 3808kps 3808kps
UP 448kps 448kps 448kps 448kps
IP Profile 1500kps 3000kps 3000kps 3000kps
Router up time 21 hrs 47hrs
SN Margin (Down) 14.5db 12.9db
07-11-2009 11:30 AM
glad the faceplate seems to have sorted your main problem. Here's something that may give you some hope -
Statistics Downstream Upstream
Line Rate 6912 Kbps 448 Kbps
Noise Margin 9.2 dB 21.0 dB
Line Attenuation 43.0 dB 22.0 dB
Output Power 19.8 dBm 12.1 dBm
So hopefully you may eventually achieve something close to my current line stats especially as your line attenuation is marginally better than mine (mind you that's got nothing to do with throughput speed I'm currently getting due to a stuck bRAS profile at 750kbps - but that's another matter!).
To get the best out of your line in current circumstances I'd suggest you try watching your noise margin throughout say a 24 hour period, you should find that it is at it's greatest in the daytime. I'd suggest a re-boot of the modem/router in the day (I'm currently recommending at least 1 1/2 hrs after sunrise & 1 1/2 hrs before sunset). You of course then need to leave the modem/router on 24/7 with no drops in connection and a low error rate for maybe upto 28 days either for the exchange DLM to lower your margin or PN to get BTw to do it.
If you have any thunder and lighting storms that cause a drop in sync that doesn't immediately recover very close to previous sync speed, I'd switch off until well after the storm has passed.
FYI, you asked in your initial post about locating problems on internal lines and voice equipment. Basically you do it by process of elimination, but as the face plate seems to be doing the trick, I wouldn't worry about it. It was most likely due to the bell wire, but it may have been a dodgy filter - just bear that in mind for future reference - I wouldn't go messing about at the moment, you want a nice stable line now.
09-11-2009 12:27 PM
Thanks for very helpful reply. I live in hopes that I will get a step up in speed and your stats help put mine into perspective. For example, I was 'concerned' that attenuation was very high particularly as I had read somewhere that each 3db of attenuation halves the possible line speed. Now I know yours is higher but your IP profile is twice mine.
Can you tell me what is BRA profile and where it fits into the complex arena of line speed?
You have suggested a reboot of the router. Is this to be done at a point when noise margin is lowest?
I have stopped trying to find any problems in the telephony side of my wiring as the ADSLNation has avoided any conflict.
My latest results after installing ADSLNation Faceplate are :
3/11 4/11 5/11 6/11 9/11
Download speed 1040kps 956kps 1098kps 1164kps 1089kps
DSL Conn rate Down 1856kps 3872kps 3808kps 3808kps 3808kps
UP 448kps 448kps 448kps 448kps 448kps
IP Profile 1500kps 3000kps 3000kps 3000kps 3000kps
Router up time 21 hrs 47hrs 110hrs
SN Margin (Down) 14.5db 12.9db 14.9db
Regards
10-11-2009 11:26 AM
Quote from: arjem Can you tell me what is BRA profile and where it fits into the complex arena of line speed?
The BRAS profile is the profile that BT set on your line, based on stored details of your sync speed each time you connect to your router (and other line stats, noise etc.). This information is then sent to us and your PN profile is set to match.
Quote from: arjem You have suggested a reboot of the router. Is this to be done at a point when noise margin is lowest?
Ideally yes - we find that generally sync speeds are higher in the mornings, so it'd be best to reboot then.
Hope that helps,
14-11-2009 11:49 AM
3/11 4/11 6/11 9/11 14/11
Download speed 1040kps 956kps 1164kps 1089kps 26044kps
DSL Conn rate Down 1856kps 3872kps 3808kps 3808kps 3904kps
Router up time 47hrs 110hrs 4 minutes
SN Margin (Down) 12.9db 14.9db 15.4db
Attenuation 40db 40db
Is the best I can expect or what can I do to get a faster download speed?
Regards.
14-11-2009 3:56 PM
Quote To get the best out of your line in current circumstances I'd suggest you try watching your noise margin throughout say a 24 hour period, you should find that it is at it's greatest in the daytime. I'd suggest a re-boot of the modem/router in the day (I'm currently recommending at least 1 1/2 hrs after sunrise & 1 1/2 hrs before sunset).
This is generally when NOISE is lowest ie SNRM is highest., not as Matt had accidently implied by saying yes to your question.
To answer your last question the answer is no, it should do better, as I said previously. This will be achieved in two ways, by getting your Target SNRM down by a long period of stabilty at a constant (or higher) sync speed. The higher sync speed can usually be achieved by re-booting if the SNRM is 1dB above you current Target when noise levels are steady during the day. Under any other circumstances it gets risky. In other words if your current Target is 15dB, which yours looks as thought it is, then a re-boot when it is at a steady 16dB or higher.
Warning though - do NOT do multiple re-boots in a short space of time. To give a good safety margin (usually) nor more than 2 or 3 times in an hour waiting a good few minutes between each, then leave it alone for the rest of the day.
To do it a safer way, powerdown and wait several minutes before powering up again or when you need to swap things around for testing, powerdown your modem/router and wait several minutes for unplugging anything that disconnects it from the line eg. it's cable, the filter, master faceplate etc. Don't do this more than 5 times in an hour, and then leave it alone for the rest of the day. This is to help prevent the exchange DLM from thinking you have an intermittent line problem..
Again I stress if you are trying to achieve a better sync, you must do it when the SNRM is stable.
14-11-2009 4:14 PM
Who knows you might be able to go even lower - provided your data error rate remains low.
14-11-2009 8:41 PM
