How to improve sync speed?
- How to improve sync speed?
01-11-2009 4:40 PM
My question is how to check internal lines and voice equipment in order to isolate the problem. The wiring is buried in the fabric of the building. Connected to the wiring are two corded phones, one answerphone and one cordless system with three handsets. Any suggestions would be appreciated.
Regards.
Re: How to improve sync speed?
01-11-2009 4:45 PM
http://www.adslnation.co.uk/products/xte2005.php
01-11-2009 4:49 PM
can you show your router stats?, if you dont know how see here http://www.kitz.co.uk/adsl/frogstats.php
01-11-2009 5:09 PM
It is possible to fit a face plate. I have been reading about the BT I-Plate and ADSLNation filtered face plate and was not certain which was appropriate or which was legal for me to fit.
I do have filters on all the phones including the answer phone.
My Router statistices are :
Mode: G.DMT
Type: Interleave
Line Coding: Trellis Off
Status: No Defect
Downstream Upstream
Rate (Kbps): 1856 448
SNR Margin (dB): 14.1 23.0
Attenuation (dB): 42.0 23.0
Output Power (dBm): 11.9 17.8
01-11-2009 5:24 PM
The I-Plate only isolates the bell wire of any extension wiring so must still be used with normal filters.
01-11-2009 5:26 PM
Note that to do this you will need to remove the wires from the removable lower faceplate and reconnect them to the filtered faceplate.
It you decide to do that you will need the following
http://www.adslnation.com/phpapps/catalog/product_info.php?cPath=24&products_id=105
http://www.adslnation.com/phpapps/catalog/product_info.php?cPath=34&products_id=93
This is the installation guide - and it is totally legal for you to do it
http://www.adslnation.co.uk/downloads/docs/XTE-2005_Guide.pdf
Note that you should only connect the wires to connections 2 and 5 as the rest are superfluous
01-11-2009 8:10 PM
Regards.
01-11-2009 8:27 PM
Re:How to improve sync speed?
02-11-2009 2:21 PM
Hopefully you should see a reduction in noise margin and an increase in sync speeds (and profile).
03-11-2009 12:32 PM
Regards
03-11-2009 12:58 PM
04-11-2009 8:54 PM
- had to reboot the router first thing this morning (4/11) as had lost connection to exchange
- just (2030hrs) run the BT speed test and results shown below compared to same test after installing faceplate yesterday
3/11 4/11
Download speed 1040kps 956kps
DSL Conn rate Down 1856kps 3872kps
UP 440kps 440kps
IP Profile 1500kps 3000kps
I read these results as I now have better potential for improved download speed but have actually achieved a slower result at this time. Are these results what I should expect after 1 day of use of the new faceplate? Will it get better?
Regards.
04-11-2009 9:04 PM
See what you get under connection settings -> high speed broadband
04-11-2009 9:06 PM
Are you sure your upstream rate isn't 448kbps
If you go here I suspect it will still show 1500kbps as it takes about 12 hours to catch up https://portal.plus.net/my.html?action=data_transfer_speed
Now all you need to do is to wait for the default noise margin to drop - this will take a few weeks - to get even faster speeds
05-11-2009 9:47 AM
Thanks Oldjim and you are correct that upload speed was reported as 448ks. I must have done a bit of rounding. I am still learning about signal noise and wondered when and how it can be improved. So from your reply it seems I just have to wait. Is signal noise affected by router connection time as the router has had to be rebooted once per day since I installed the ADSLNation faceplate?
