How to get stats from a router?
Strike
When I login to admin on Technicolor TG582n router, I can't find any link to show me what the upload and download are currently connected.
I like to see stats from a router.
Fixes: 58
Re: How to get stats from a router?
You can't as you are on fibre
Other than hacking the modem the only way to get an indication of download speed is the BT IP profile and multiply it by 1.033
Fixes: 9
Try http://192.168.1.254/cgi/b/dsl/dt/?be=0&l0=2&l1=0
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
shalom2010
Above only works on DSL not FTTC! It actually shows on my 582n on fibre as DSL Disconnected!
dick:quote
Fixes: 9
That's to be expected as the router is not connected to any DSL - it's the modem that does that.
PS I suggest you change your signature before you get in to trouble with the moderators! See http://community.plus.net/forum/index.php/topic,218.0.html#post_avatar
shalom2010
Okay, sorry did not realise, hope this is better?
jim:quote
Estragon
Quote from: jelv
Pah! "The use of advertising links which confer a benefit to the poster are is not acceptable."
Strike
So it is not possible to find what the max speed currently connected from a modem or router? Thats Odd.
Basically I have to use speedtest.net or BT speedtest to check..
Fixes: 46
You need your BT IP Profile, not a speedtest result. To get your BT IP Profile you need to do a BT speedtest, than ask for Further Diagnostics and enter your phone number. Then as Oldjim said multiply that value by 1.033.
David
