How to convert 1 port router to multiport router?
- Re: How to convert 1 port router to multiport rout...
31-01-2012 4:09 AM
Hi folks,
My pc is connected to broadband via ethernet cable using a Speedtouch St-516 1-port router that I received from PN when I signed up. My problem now is that I need more ports, at least 2, so I can connect my blu-ray player to the internet, and also I hear that Anytime+ Plus from Sky will be opened up to all Sky subscribers and not just Sky broadband users, from this Easter.
So my question is: How can I "split" the 1 port into 4 ports or should I just buy a new router? Which is easier or cheaper?
If you recommend I buy a new router then can you tell me which one would be best?
Many thanks
Many thanks
Message 1 of 5
(1,067 Views)
4 REPLIES 4
Re: How to convert 1 port router to multiport router?
31-01-2012 9:20 AM
I'm not familiar with the Speedtouch kit, but you should be able to plug in a cheap 5 port switch. Something like this:
http://www.amazon.co.uk/TP-Link-Unmanaged-Desktop-TL-SF1005D-Plastic/dp/B000FNFSPY/ref=sr_1_1?ie=UTF...
Message 2 of 5
(574 Views)
31-01-2012 9:32 AM
Just had a quick look at the ST-516, and I think it'll be fine.
Zero config, and much cheaper than a new router at £7, but remember you'll need power close by to plug it in.
Message 3 of 5
(574 Views)
31-01-2012 10:06 AM
If you ask support and agree to sign up for another 12 months I expect you can get anyone router free and only have to pay P&P.
James
Message 4 of 5
(574 Views)
31-01-2012 10:32 AM
Quote you ask support and agree to sign up for another 12 months I expect you can get anyone router free and only have to pay P&P.
Yes, we can do this. If for what ever reason you needed to leave within that 12 month period the only upshot would be having to pay £40 for the router, otherwise after the year it's yours.
Let me know if that's what you want to do.
Message 5 of 5
(574 Views)
