How to check if UPD / TCP ports are unrestricted?
titan03018
I am trying to set up my VPN with my new Technicolor TG582n router and have been asked the following
Check that the following ports are allowed and unrestricted: UDP 1194, 8080, 9201 and TCP 110, 443, 500.
How do I do this? Is it a setting within the router access or something to do with Telnet?
Any help would be very welcome!
Re: How to check if UPD / TCP ports are unrestricted?
This should work for you as standard, the software that you're using should automatically configure this for you.
Fixes: 60
The fact that you're being asked about TCP ports 443 & 500 tends to indicate that it's an IPSec VPN. Depending on the f/w version you may need to apply the 'fix' detailed here http://npr.me.uk/vpnissue.html
