How to check if UPD / TCP ports are unrestricted?
- Re: How to check if UPD / TCP ports are unrestrict...
23-10-2013 6:31 PM
I am trying to set up my VPN with my new Technicolor TG582n router and have been asked the following
Check that the following ports are allowed and unrestricted: UDP 1194, 8080, 9201 and TCP 110, 443, 500.
How do I do this? Is it a setting within the router access or something to do with Telnet?
Any help would be very welcome!
Message 1 of 3
(2,535 Views)
2 REPLIES 2
Re: How to check if UPD / TCP ports are unrestricted?
24-10-2013 10:39 AM
This should work for you as standard, the software that you're using should automatically configure this for you.
Message 2 of 3
(619 Views)
24-10-2013 11:37 AM
The fact that you're being asked about TCP ports 443 & 500 tends to indicate that it's an IPSec VPN. Depending on the f/w version you may need to apply the 'fix' detailed here http://npr.me.uk/vpnissue.html
Message 3 of 3
(619 Views)
