How soon can I gateway hop?
- Re: How soon can I gateway hop?
23-10-2010 10:44 AM
I have just done a "gateway hop" and increased myy synch speed by one level..... how soon after that "hop" can I do another? to see if it will increase the sync speed to the next level?
(line is stable, and routerstats show 7db with a level trace, (very few noise spikes, and then only .5db )
Message 1 of 4
(760 Views)
3 REPLIES 3
23-10-2010 10:52 AM
"Gateway Hop" per se doesn't affect sync speeds as it doesn't require a resync at the exchange
A resync in mid morning, as you appear to have done, should give the best result.
I doubt that a further resync during the day will have any significant effect
Message 2 of 4
(339 Views)
23-10-2010 11:01 AM
Thanks Jim.... my overnight snr dropped from 6 to 3.5 and then, while I was asleep, something made the line drop and when I re-started the computer this morning, the sync speed had dropped with a snr of 7.... this resulted in my BT synch dropping speed, and my throughput speed too... so did the "hop" to bring the synch speed up ...
just wondered if I did another one later on (say 2-3pm ish) if I might get the synch speed up another level.... or should I wait until tomorrow at 10 ish?
Message 3 of 4
(339 Views)
23-10-2010 11:25 AM
Its a game of chance, last time mine did that it took a full three days before it went up
Message 4 of 4
(339 Views)
