How soon after activation should your IP Profile edge up?
- How soon after activation should your IP Profile e...
26-10-2007 12:15 AM
Just to clarify - I've only had this line active for a week, and I'm just wondering how much longer I should expect to wait for an upgrade in speed. Part of me is wondering whether, in fact, I should already have had a boost and am the subject of a mistake somewhere along the line.
Below is a typical result from BT's speed testing site, and I've managed to test many times (with one test between midnight and 6am - as mentioned somewhere in the literature), all with practically identical results.
Feel free to tell me to shut up, and that things will improve in the fullness of time. I'd just like to have an idea of how full it should get - and when that would be
Many thanks for reading the whole thing!
Gwydion
From www.speedtester.bt.com - typical result
IP profile for your line is - 2000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 5760 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1737 kbps
http://dewin.net/bttest.jpg - another typical result.
ps: I first mentioned the problem in a posting to another thread which can be found here. Yes, I'm impatient. For that I apologise.
Re: How soon after activation should your IP Profile edge up?
26-10-2007 9:45 AM
It's actually showing as having you on a 5000Kbps profile since yesterday.
Could you try rebooting and running another BT speedtest?
26-10-2007 9:53 AM
When the training period is over and when you achieve a sync you find suitable, it will take 3 days for your BT profile to catch up - you can see this at anytime rather than running speedtests from the High Speed Broadband icon under connection settings
Mine is just starting to stable out and it's been active for 2 1/2 weeks
26-10-2007 10:28 AM
DSL connection rate: 448 kbps(UP-STREAM) 7328 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1841 kbps
Doesn't appear to be much sign of a higher profile, unfortunately.
Thanks for the comment too pcoventry76, I'm just concerned that the profile hasn't moved at all - despite my having (from what I can see) a pretty rock solid 5mb connection rate. I guess I'll have to wait until the 10 days are up.
26-10-2007 10:29 AM
I've seen a couple instances of stuck profiles over the last week. Can you possibly bear with it for a couple of days and see if the IP Profile has gone up?
If it hasn't then please let me know and I'll raise a fault with BT on Monday.
26-10-2007 10:32 AM
you have an awesome sync there so please don't reboot your modem anymore. as repeated reboots and bt starts to think there is a problem
26-10-2007 10:34 AM
Quote repeated reboots and bt starts to think there is a problem
We're talking about a number of reboots on a daily basis.
A daily reboot is recommended, particularly in the first 10 days of the IPStream Max service.
26-10-2007 10:35 AM
Some people may constantly reboot several times a day in the hope that their sync will improve their throughput.
In this situation they will be stuck in a circle.
26-10-2007 10:54 AM
I'll stick with it, and may or may not be in touch when monday comes around the corner.
29-10-2007 11:41 AM
back again with no changes in profile over the weekend, and now I get an error message from the speed tester:
The IP address discovered on the network associated with your telephone number:(snip - my edit), did not match the one we have logged from this browser/connection. Please check your telephone number and try again. If problem persists please contact your CP.
Anyone have any ideas? Pretty sure the profile needs nudging too
29-10-2007 11:44 AM
I'm seeing profiled speeds of 5000Kbps on both the BT and PlusNet end.
Last update was on the 28th.
29-10-2007 11:50 AM
Thanks for the prompt response
29-10-2007 11:54 AM
It happened to me quite a few times when i first got MAXed back last march. Not sure whether this happens still.
James Barlow
29-10-2007 11:54 AM
DSL connection rate: 448 kbps(UP-STREAM) 7392 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1845 kbps
Argh.
29-10-2007 11:58 AM
I've seen a few instances recently of BTs systems taking 24-48 hours to update.
If it's not been amended in a day or so, let me know and I'll raise a fault with them.
