How slow can you go...!
- How slow can you go...!
07-02-2014 5:08 PM
http://www.thinkbroadband.com/speedtest/results.html?id=139179237016490451481
I've done all the usual tests - wires, dial tone, reboots, etc... with no effect
Any ideas please?
Re: How slow can you go...!
07-02-2014 5:14 PM
I'm just looking into this for you. Please bear with me and I'll do my best to get this sorted out for you.
Cloud Environments Engineer
07-02-2014 5:17 PM
Its been like this for a couple of days... download speed is consistently around 128kbps... with upload being quicker...
Nothing has changed my side, except the poor weather... I've checked the outside connections but nothing wrong - all dry and OK.
Phone works fine too - clear sound.
Jon
07-02-2014 5:19 PM
I appreciate the call wait times are a little high at the moment but we're making improvements and we'll get there!
Yeah there looks to be something happening with the Speed Profile set by our suppliers - I'm just on with them now to try and get this sorted out for you.
Shouldn't be too long!
07-02-2014 5:29 PM
That should be sorted for you now. Give or take an hour, you should start to notice the speeds back to normal.
07-02-2014 6:35 PM
Posted via Mobile connected to Orange ("Zero Range")
07-02-2014 6:56 PM
When you say no connection, do you mean just Internet or no phone service at all? If the latter, then raise a phone line fault with your phone supplier. If the phone works, is line line noisy? If yes raise a voice fault likewise.
Otherwise, check connects, try a new filter. Do you have a spare router? Raise a fault report here http://faults.plus.net
07-02-2014 7:01 PM
I've checked everything ... nothing has changed, and connection was fine this afternoon just really slow!
Phone is fine - calls are clear.. no noise on line.
Whatever was changed at server end has killed the connection.
07-02-2014 7:11 PM
08-02-2014 1:30 AM
08-02-2014 11:18 AM
08-02-2014 11:52 AM
I'm outof the office at the moment but if the issue is still ongoing could you please PM me your contact details and I'll do my best to help.
08-02-2014 4:49 PM
http://www.thinkbroadband.com/speedtest/results.html?id=139187772353500481224
08-02-2014 10:24 PM
