How low will Plusnet slow down connection speeds to force FTTP uptake ?
Ochso
Ever since the erection of the Fibre carrying posts and line wiring .. I have been Hard capped by Plusnet/ BT wholesale. And its beginning to get annoying.
Hard capping started last year (Data from Hub 2 Router logs)  This started within a week of the new post ( leaning btw)  being put up.
Previous speeds : on my 40/10  line .
01:53:26, 23 Oct. DSL Link Up: Down Rate=36438kbps, Up Rate=8132kbps;
To the 1st Hard cap Date 05/12/23
03:26:24, 05 Dec. DSL Link Up: Down Rate=30000kbps, Up Rate=7774kbps;
Made zero difference in any rebooting of router (at any time of day ) connection speed remained locked.
Then came April 3rd 2024  ;
04:32:35, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6993kbps;
No its nothing to do with copper  this is a deliberate hard cap  ( odds on getting exact synching stats are astronomical btw)
Then If you add Pnets changing of speeds for the area on thier website pages to the speeds they are capping to , some what laughable - if I were not paying for more for the subterfuge.
Oh I can get a 'Fibre' package - a further 4 Mbs slower   than the 27.4Mbs I am being hard capped to   ( guess where the next hard cap speed is going to hit ?)
Pretty soon  I shall No doubt be at ADSL speeds  In this rather pathetic marketing ploy.
Product code:Plusnet Hub Two
Serial number:
Firmware version:
Firmware updated:30-Jun-2023
Board version:R01
GUI version:1.9 16_08_2022
DSL uptime:
Data rate:6.601 Mbps / 27.4 Mbps
Maximum data rate:6.684 Mbps / 33.994 Mbps
Noise margin:6.1 / 9.1
Line attenuation:6.9 / 22.1
Signal attenuation:6.9 / 25.2
VLAN id:101
Seriously frustrated
10 REPLIES 10
Fixes: 334
Re: How low will Plusnet slow down connection speeds to force FTTP uptake ?
@Ochso Your (edited) Tech stats say it all really - you have an elevated D/S SNR, which means the DLM hardware in the OR network is attempting to stabilise a bad line. What is your DSL uptime?
Have you tried running the Plusnet fault detection 'bot' ?
Moderator's note(s):
Unhelpful part of post removed.
Ochso
Yes currentl;y have an on going reported fault  thaA coincided on  the day the  line went slower
Line   27: 16:55:40, 04 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=7143kbps; SNR Margin Down=9.8dB, Up=6.0dB
    Line  118: 14:20:27, 04 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6339kbps; SNR Margin Down=8.5dB, Up=6.0dB
    Line  183: 12:21:31, 04 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=7197kbps; SNR Margin Down=9.8dB, Up=6.0dB
    Line  246: 11:51:42, 04 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6937kbps; SNR Margin Down=9.8dB, Up=6.1dB
    Line  315: 10:45:07, 04 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=7164kbps; SNR Margin Down=9.8dB, Up=6.0dB
    Line  393: 09:24:03, 04 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=7164kbps; SNR Margin Down=9.5dB, Up=6.0dB
    Line  712: 08:18:24, 04 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=7160kbps; SNR Margin Down=9.9dB, Up=6.1dB
    Line  776: 07:46:02, 04 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=3491kbps; SNR Margin Down=7.1dB, Up=0.0dB
    Line  923: 05:17:29, 04 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6888kbps; SNR Margin Down=9.0dB, Up=6.0dB
    Line  997: 03:00:48, 04 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6924kbps; SNR Margin Down=9.1dB, Up=6.0dB
    Line 1065: 02:13:05, 04 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6813kbps; SNR Margin Down=9.1dB, Up=6.0dB
    Line 1130: 01:19:05, 04 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6866kbps; SNR Margin Down=9.2dB, Up=6.0dB
    Line 1193: 00:48:07, 04 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6055kbps; SNR Margin Down=8.1dB, Up=6.1dB
    Line 1270: 22:35:10, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=7132kbps; SNR Margin Down=8.9dB, Up=6.0dB
    Line 1347: 21:37:02, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=7044kbps; SNR Margin Down=9.6dB, Up=6.1dB
    Line 1403: 21:35:18, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=5676kbps; SNR Margin Down=5.3dB, Up=6.0dB
    Line 1508: 21:25:35, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6637kbps; SNR Margin Down=7.8dB, Up=6.0dB
    Line 1592: 20:52:18, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=7179kbps; SNR Margin Down=8.9dB, Up=6.0dB
    Line 1666: 20:00:57, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=7198kbps; SNR Margin Down=9.5dB, Up=6.4dB
    Line 1730: 19:53:45, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6650kbps; SNR Margin Down=9.2dB, Up=6.0dB
    Line 1798: 19:26:41, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6806kbps; SNR Margin Down=9.4dB, Up=6.1dB
    Line 1866: 18:46:43, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6686kbps; SNR Margin Down=9.5dB, Up=6.0dB
    Line 1931: 17:52:08, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6944kbps; SNR Margin Down=9.6dB, Up=6.0dB
    Line 2002: 16:44:33, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6586kbps; SNR Margin Down=9.6dB, Up=6.1dB
    Line 2080: 16:27:30, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6534kbps; SNR Margin Down=9.5dB, Up=6.0dB
    Line 2143: 16:09:54, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6738kbps; SNR Margin Down=9.7dB, Up=6.1dB
    Line 2209: 16:00:09, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6558kbps; SNR Margin Down=9.5dB, Up=6.0dB
    Line 2269: 15:38:20, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6551kbps; SNR Margin Down=9.6dB, Up=6.0dB
    Line 2333: 14:40:49, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=7136kbps; SNR Margin Down=9.8dB, Up=6.1dB
    Line 2398: 14:06:12, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6526kbps; SNR Margin Down=9.8dB, Up=6.1dB
    Line 2465: 14:01:26, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6828kbps; SNR Margin Down=9.7dB, Up=6.0dB
    Line 2524: 13:32:51, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6594kbps; SNR Margin Down=9.7dB, Up=6.0dB
    Line 2636: 13:25:50, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6414kbps; SNR Margin Down=8.7dB, Up=6.0dB
    Line 2699: 12:04:45, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=7143kbps; SNR Margin Down=9.8dB, Up=6.0dB
    Line 2829: 10:24:16, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=7079kbps; SNR Margin Down=9.7dB, Up=6.1dB
    Line 2862: 10:04:02, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6682kbps; SNR Margin Down=9.7dB, Up=6.0dB
    Line 2899: 09:16:30, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=7198kbps; SNR Margin Down=7.4dB, Up=0.0dB
    Line 2949: 08:52:46, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6944kbps; SNR Margin Down=9.8dB, Up=6.1dB
    Line 2978: 08:38:19, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=7029kbps; SNR Margin Down=9.6dB, Up=6.0dB
    Line 3012: 07:51:24, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=7096kbps; SNR Margin Down=9.3dB, Up=6.0dB
    Line 3041: 07:29:37, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=7198kbps; SNR Margin Down=8.4dB, Up=7.9dB
    Line 3070: 07:07:42, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=7198kbps; SNR Margin Down=9.6dB, Up=6.1dB
    Line 3096: 07:06:42, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=7198kbps; SNR Margin Down=5.2dB, Up=5.9dB
    Line 3123: 06:01:21, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=7001kbps; SNR Margin Down=9.6dB, Up=6.1dB
    Line 3144: 06:00:25, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=7198kbps; SNR Margin Down=5.3dB, Up=6.0dB
    Line 3172: 04:32:35, 03 Apr. DSL Link Up: Down Rate=27400kbps, Up Rate=6993kbps; SNR Margin Down=9.6dB, Up=6.0dB
The 30 Mb Speed was steady as were  my previous speeds 34Mb+ plus speeds.. yet to hit an exact amount every time the router reboots is a hard limit.  I could live with 30 ( just about though  MSFS no longer a viable past time for me)  but the current state of affairs plus the inmpending next hard cap lowering  is way out of line
So I  vent.
Fixes: 334
As I said previously - you have a fault - until that is rectified, the DLM will continue to intervene. Once it is fixed - then is the time to ask PN for a DLM reset - IF the system doesn't automatically reset it.
Fixes: 528
As has been stated, Plusnet have no control over the speeds , it's down to the Openreach DLM.
What Plusnet should be doing, is arranging an Openreach engineer visit to investigate and fix the line problem
@Ochso  because your line is unstable, the Openreach DLM has put you on lower and lower fixed speeds in an attempt to stop your connection constantly dropping out.  You have a fault which needs Openreach to repair.  Once the fault is gone, then a DLM reset will restore your normal speeds.
I've had broadband for 25 years, and I've NEVER had my line (when banded) recover automatically, it always needs manual intervention.
Ochso
Im not holding my breath tbh .   This is the  "deal "thats  being offerred to me  And the speeds they are going to drop me into -  one way or another.
Maybe its my paranoia who knows but that is  A definitive slow down in offered speeds.
Just wish I had saved my router logs earlier  Mind you that would have increased the frustration
Plusnet's offer speeds are individually calculated from Openreach's database, which is based on the current performance of your specific connection.  While you have an ongoing fault, your reported range of line speeds will be lower than expected.
Once your line is repaired, then the numbers will recover to mirror the improved speeds.
corringham
Seasoned Champion
Fixes: 23
The problem with Plusnet's offer speeds being calculated from the line's current speed, is that if the contract is accepted it is almost certain that the minimum guaranteed speed will be below the current speed - thereby ensuring that no action will be taken to get the speed back up to where it used to be.
Ochso
Looks like the writing is on the wall for My area .. Current  "Deals" being offered on FttC with a landline to new customers.
Bt Wholesale are probably using the Marketing equivalent of constructive dismissal.
For me it is more cost effective to have the VMedia 350 Package for my internet needs  and let this current contract run its course. and keep my land line running for as long as possible..    Rather than cancellation , paying early termination and re-sourcing ..
Will see how well the engineer can stabilise the line again Still not holding my breath  for anything like the speeds of  6 months ago
