How long should I wait?
- How long should I wait?
13-03-2013 5:53 PM
Been with Plusnet for 10 years + and very pleased.
Speeds until recently have been 19 down and 1 up and rock solid.
Nothing has changed with modem or line or anything.
Today I checked and down speed has decreased to 1MBps. I have not noticed disconnections.
Modem connecting at 23001, BT speedtest shows fault as after 3rd test the down and up speed was 0. MyIP profile is 23.4.
Is this due to the recent problems or have I got an issue?
Chris.
Chris.
Message 1 of 7
(1,155 Views)
6 REPLIES 6
Re: How long should I wait?
13-03-2013 7:37 PM
Hi Chris,
Another Chris here
It looks as though you've had a low sync event, could have been triggered by many things such as poor weather or an engineer working on a nearby line for example.
I've just made some changes to your Speed Profile, can you disconnect and reconnect from within your router and run a further Speed Test please?
Another Chris here
Message 2 of 7
(599 Views)
13-03-2013 8:10 PM
Cheers Chris!
Back up to 19.2 on speedtesting.
This is what makes Plusnet so great.
(If only I could now get Fibre!)
Chris.
Chris.
Message 3 of 7
(599 Views)
13-03-2013 8:13 PM
Excellent!
Worth keeping an eye on this for Fibre: http://www.superfast-openreach.co.uk/where-and-when/
You never know, it could come faster than you think!
Message 4 of 7
(599 Views)
13-03-2013 8:16 PM
You can email nga.enquiries@openreach.co.uk and they will tell you when roughly when (or if) you are going to get fibre - you need to give your postcode and phone number so they know which cabinet you're connected to. Expect to wait a few weeks for an answer though...
Message 5 of 7
(599 Views)
13-03-2013 8:17 PM
Hmm, interesting.
I had thought that because I am very close to the exchange (hence great ADSL2+ speeds) that my line was not suitable for fibre.
Time will tell.
Chris.
Time will tell.
Chris.
Message 6 of 7
(599 Views)
13-03-2013 8:18 PM
Thanks AndyH I shall give it a go.
Chris.
Chris.
Message 7 of 7
(599 Views)
