How long for SNR to go down?
ID
About 4 days after my BT phone fault was fixed See here. My router must have had a bad night. Woke up to find it at 10DB and tried a reboot which showed my target is now 9DB.  I didn't want to ask for an SNR reset as I had one back in January. I haven't had 1 disconnect since the reboot and am not sure if a solid 23day uptime is enough to think about trying a another reboot. Will it do it itself?
DSL Connection
Link Information:
Uptime:24 days, 9:58:00
DSL Type:G.992.1 annex A
Channel mode:Fast
Maximum Bandwidth (Up/Down) [kbps/kbps]:1,144 / 6,976
Bandwidth (Up/Down) [kbps/kbps]:832 / 6,976
Data Transferred (Sent/Received) [kB/GB]:0.00 / 91.18
Output Power (Up/Down) [dBm]:12.5 / 19.5
Line Attenuation (Up/Down) [dB]:15.5 / 32.5
SN Margin (Up/Down) [dB]:15.0 / 8.5
Vendor ID (Local/Remote):TMMB / TSTC
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
Error Seconds (Local/Remote):22 / 0
FEC Errors (Up/Down):1 / 0
CRC Errors (Up/Down):437 / 7,191
HEC Errors (Up/Down):3 / 7,780
My IP profile is now 6000. I know it's only half a meg to a meg slower but I do miss it  Embarrassed
Fixes: 23
Re: How long for SNR to go down?
I timed this after a line fault pushed up my target noise margin.  Each 3dB improvement took around 400 hours.  That was on ADSL; I suppose ADSL2+ might be different.  Each step change was spontaneous, I did not need to force it by restarting the router.
ID
Thanks for your reply.
Think I will give it another week and hope it does it itself.
Hope it's not too long before we get ADSL2+ / Fibre.
Hi ID,
You have had a sync of 14 days, it would certainly be quickest to do a SNR reset on your line, as it can take roughly 72 hours after a sync to adjust without a SNR reset.
There certainly no issue from me to do a SNR reset as your line is very stable, so I can go ahead with that if you like?
Chris
ID
Yes please Chris. Would appeciate that  Smiley
That's been done for you, this normally takes up-to 4 hours but can sometimes take up-to 24 hours.
Anything else then just let me know.
ID
Hi Chris, It doesn't look like it took.
  Internet
  View more...
TypeTonguePPoA
Uptime:17 days, 4:40:41
  DSL Connection
  Link Information
Uptime:27 days, 10:52:10
Channel mode:Fast
Data Transferred (Sent/Received) [kB/GB]:0.00 / 98.98
Error Seconds (Local/Remote):129 / 0
FEC Errors (Up/Down):13 / 0
CRC Errors (Up/Down):466 / 16,657
HEC Errors (Up/Down):15 / 64,370
Fixes: 23
For some reason these "resets" don't always take.  On the other hand, the last reset I asked for (via on online chat support service with Demon) happened about 5 minutes later and cut-off the conversation.
Hi ID,
I'd suggest doing a soft disconnect, by logging into your router, disconnecting and then reconnecting.
Let me know when you have done this, if it hasn't improved I'll have a further look for you.
Chris
ID
Just an update. I tried the soft reboot on Tuesday with no effect. I left it over 24hrs and tried a full reboot. This did the trick  Grin Now syncing at 7872.
Cheers for all your help. Much appreciated.
That's magic Cheesy all back up to normal then.
Any further changes let me know
Fixes: 23
Quote from: chrispurvey
Does this ever work?  I have never seen a soft disconnect cause a renegotiation of the rates.
