How long for SNR to go down?
- Re: How long for SNR to go down?
02-08-2012 6:19 PM
DSL Connection
Link Information:
Uptime:24 days, 9:58:00
DSL Type:G.992.1 annex A
Channel mode:Fast
Maximum Bandwidth (Up/Down) [kbps/kbps]:1,144 / 6,976
Bandwidth (Up/Down) [kbps/kbps]:832 / 6,976
Data Transferred (Sent/Received) [kB/GB]:0.00 / 91.18
Output Power (Up/Down) [dBm]:12.5 / 19.5
Line Attenuation (Up/Down) [dB]:15.5 / 32.5
SN Margin (Up/Down) [dB]:15.0 / 8.5
Vendor ID (Local/Remote):TMMB / TSTC
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
Error Seconds (Local/Remote):22 / 0
FEC Errors (Up/Down):1 / 0
CRC Errors (Up/Down):437 / 7,191
HEC Errors (Up/Down):3 / 7,780
My IP profile is now 6000. I know it's only half a meg to a meg slower but I do miss it
02-08-2012 9:14 PM
03-08-2012 12:19 PM
Think I will give it another week and hope it does it itself.
Hope it's not too long before we get ADSL2+ / Fibre.
03-08-2012 1:49 PM
You have had a sync of 14 days, it would certainly be quickest to do a SNR reset on your line, as it can take roughly 72 hours after a sync to adjust without a SNR reset.
There certainly no issue from me to do a SNR reset as your line is very stable, so I can go ahead with that if you like?
Chris
03-08-2012 4:34 PM
03-08-2012 4:40 PM
Anything else then just let me know.
05-08-2012 7:08 PM
Internet
View more...
Type:PPPoA
Uptime:17 days, 4:40:41
DSL Connection
Link Information
Uptime:27 days, 10:52:10
Channel mode:Fast
Data Transferred (Sent/Received) [kB/GB]:0.00 / 98.98
Error Seconds (Local/Remote):129 / 0
FEC Errors (Up/Down):13 / 0
CRC Errors (Up/Down):466 / 16,657
HEC Errors (Up/Down):15 / 64,370
06-08-2012 6:22 AM
06-08-2012 2:44 PM
I'd suggest doing a soft disconnect, by logging into your router, disconnecting and then reconnecting.
Let me know when you have done this, if it hasn't improved I'll have a further look for you.
Chris
09-08-2012 4:18 PM
Cheers for all your help. Much appreciated.
09-08-2012 5:11 PM
Any further changes let me know
09-08-2012 5:23 PM
Quote from: chrispurvey I'd suggest doing a soft disconnect, by logging into your router, disconnecting and then reconnecting.
Does this ever work? I have never seen a soft disconnect cause a renegotiation of the rates.
