How hard can it be to get a fault sorted?
- How hard can it be to get a fault sorted?
- « Previous
- 1
- 2
- Next »
Re: How hard can it be to get a fault sorted?
01-05-2013 12:47 PM
I'll wait and see how the fault progresses thanks. I haven't added the results from the tests last night to the ticket in case it is now irrelevant but can add them if required.
Message 16 of 21
(314 Views)
08-05-2013 12:54 PM
Things are looking up eventually Sync back at 8128, pings under 30 (after the openreach visit they enabled interleaving and pings was up at 60ms) just need the IP profile to get updated now
Quote Download speed achieved during the test was - 5.32 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.83 Mbps(UP-STREAM)
IP Profile for your line is - 5.5 Mbps
Message 17 of 21
(314 Views)
08-05-2013 2:16 PM
Glad to see that looks better, let me know anything changes.
Message 18 of 21
(314 Views)
08-05-2013 9:40 PM
How long does it take for the IP profile to lift? It's been running at 8128 for a couple of days now and I have done the requested reboot in the ticket.
Message 19 of 21
(314 Views)
08-05-2013 9:51 PM
It should have happened by now. See http://www.kitz.co.uk/adsl/IPprofile.htm#IPprofile_increase_time
Message 20 of 21
(314 Views)
09-05-2013 11:32 AM
Hi Bud,
We've been in-touch with our suppliers who have manually adjusted your IP profile, you should see the difference in the next hour or so.
Message 21 of 21
(314 Views)
- « Previous
- 1
- 2
- Next »
