How easy is it to leave?
- How easy is it to leave?
13-11-2007 12:48 PM
Hi all,
I remember a while back when LLU first started that people (once LLU'd) were unable to move away from PlusNet for some reason.
Is this still the case or is it as easy as getting a MAC code now?
Message 1 of 5
(1,479 Views)
4 REPLIES 4
Re: How easy is it to leave?
13-11-2007 12:54 PM
It isn't the mafia you know.
You can ask (and be given) a MAC at any time.
Message 2 of 5
(504 Views)
13-11-2007 12:54 PM
You can get a MAC for migrating an LLU service back to BT, though the process does take a little longer due to it taking 5 working days to get the MAC from the LLU supplier. It isn't any slower for BT to do the work though.
Hope that helps,
Hope that helps,
Message 3 of 5
(504 Views)
13-11-2007 1:00 PM
Nice one thanks. Was pretty sure it must be fairly painless, just remember some people getting rather heated when they were first migrated to LLU.
Thanks again.
Thanks again.
Message 4 of 5
(505 Views)
13-11-2007 1:04 PM
Hi Dustjunky,
I've just tried giving you a ring, but there's no answer as presumably you're at work
Can I ask why you are looking to leave? Anything I can help with?
Message 5 of 5
(505 Views)
