How do you turn off interleaving
- How do you turn off interleaving
04-04-2009 11:05 AM
My ping is always much higher than my team mates. How do I try it with interleaving off?
Link Information
Uptime: 2 days, 13:48:33
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,536
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 1.00
Output Power (Up/Down) [dBm]: 12.0 / 17.0
Line Attenuation (Up/Down) [dB]: 31.5 / 59.0
SN Margin (Up/Down) [dB]: 18.0 / 12.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 94 / 0
Loss of Signal (Local/Remote): 13 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 248 / 0
FEC Errors (Up/Down): 1 / 519,678
CRC Errors (Up/Down): 1 / 8,256
HEC Errors (Up/Down): 0 / 7,146
Link Information
Message 1 of 3
(1,168 Views)
2 REPLIES 2
Re: How do you turn off interleaving
04-04-2009 1:41 PM
You are on quite a long line there, so you may end up with an unstable situation, but always worth a try. If you login into the member centre and go to your broadband settings you may have an option here to turn it on or off. If not, just raise a ticket, stating you are a gamer and your pings are too long so you'd like to try your line with Interleaving off.
Message 2 of 3
(385 Views)
04-04-2009 1:49 PM
takes around 24 hours from request to being turned on / off and normaly BTw do this at about 2am . so if your line doesn't suit fast path it's pretty quick to reverse.
Message 3 of 3
(385 Views)
