How do you resolve a Bridged Tap?
rolya
My in-laws have this condition on their line, but I have no idea how to resolve. Would like to get them on fibre, but this is blocking. Can anyone advise?
Fixes: 412
Re: How do you resolve a Bridged Tap?
A bridge tap is usually caused by internal wiring. Do they have a test socket as explained below?
https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
Anoush
rolya
No idea. Will have to take a look, it's an old tied cottage.
if I find one, I just do some tests? If it doesn't what then?
Moderator's note by Adie (Dvorak): Full quote of preceding post removed as per the forum rules
Fixes: 412
If it has a test socket, I'd recommend plugging the router into that and see if the bridge tap is still present.
We should be able to find out by testing your line so feel free to PM me their username once it's in the test socket.
If there is no test socket, it's a bit of a difficult situation. They could arrange for a third party, qualified engineer to take a look at their internal wiring, or risk an upgrade to fibre and if problems develop we can arrange an engineer visit.
The latter option would incur a callout charge of £65 if the issue turns out to be internal and the engineer may provide an updated master socket with a test socket.
Fixes: 11
If you can post a few pictures of the main socket it will give us few clues to help you.
E.g. A picture of the socket and a picture of the wiring if you open the socket.  plus any details of junction boxes present.  Some of these older installations can be a pain!  Check if there are any extensions - and whether they are still needed / used?
Fixes: 19
I thought that the Bridge Tap status only shows up if they're already on FTTC? What's telling you that there is a Bridged Tap? They could still get FTTC anyway, the speed would just be a bit slower.
Fixes: 412
That's a good point.
That'll be interesting to know.
Browni
Aspiring Hero
Fixes: 45
http://dslchecker.bt.com/ shows it at the bottom
How accurate that is is anybody's guess.
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
Fixes: 19
Yes, but I think it just shows as U for Unknown on ADSL lines.
rolya
Yes it was this site
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Seems now it what's reverted to a U status.
thank you for confirming that even if there is a Bridged tap, the line would still work if flipped to fibre
I will keep you posted on how this pans out, including the line checks when I get there in the next week or so
cheers all :-)
