How do you change the IP address on a technicolor gateway?
- How do you change the IP address on a technicolor ...
29-09-2012 9:59 PM
Thank you!
Liz
Re: How do you change the IP address on a technicolor gateway?
29-09-2012 10:44 PM
are you talking about the internal LAN IP addresses?
29-09-2012 11:15 PM
29-09-2012 11:55 PM
Quote from: lizc I'm talking about the IP address I type into the address bar in my search engine to access the router.
That sounds like the internal LAN IP address to me. Which (from memory) would be 192.168.1.254 by default.
29-09-2012 11:58 PM
On the router you'll have to change the sub-net, the router's IP and the IP's given out by the DHCP. (Also it's possible if you've allocated a specific IP to your PC instead of letting it get it from the router you'll have to change the IP of the PC).
30-09-2012 6:09 PM
I don't know what subnet is used by the VPN but all the IP addresses I can see associated with it begin 192.168.1
The VPN connects to a specific server IP address and is given an IP address beginning 192.168.1
Still no clue where to start I'm afraid!
30-09-2012 7:24 PM
Go to Home > Home Network > Interfaces > LocalNetwork
and then hit configure and scroll down to
192.168.1.254/24 and hit edit and change to 192.168.2.254/24
and then also edit
LAN_custom 192.168.1.30 - 192.168.1.253 192.168.1.254 and swap the .1. to .2.
Hit save and reboot router and pc and that should resolve the vpn issue
30-09-2012 7:38 PM
I did the first step you suggested but there was no LAN_custom field. I've rebooted the router but can't get any access or internet. Any suggestions?!
30-09-2012 7:54 PM
30-09-2012 8:24 PM
30-09-2012 8:34 PM
Failing all else try a hard reset of the router which will set it back to defaults
However you will then probably need to enter your Plusnet login details manually
30-09-2012 8:36 PM
30-09-2012 8:41 PM
30-09-2012 8:42 PM
30-09-2012 9:04 PM
Any ideas how to change the IP address without locking me out?!
