How do I view my tickets?
sukeshn
I called support and logged a ticket about my intermittently failing connection, but how can I see the status of it?
The member centre is not very intuitive, can someone guide me as to where I can see the status of a ticket so I can add further comments?
Fixes: 144
Re: How do I view my tickets?
Have a look here https://www.plus.net/wizard/?p=search
Customer and Forum Moderator. Windows 10 Firefox 62.0.3 (64-bit)
sukeshn
I went to that section before.
Where to go from there?
RealAleMadrid
Aspiring Champion
Fixes: 16
Are you aware that questions and tickets are the same thing? Just check for open questions. Smiley
Acassim
Hi sukeshn,
You should be able to select the viewing options at the link that Strat provided. Once you've logged in you should then see a drop down list which gives the options for viewing.
