How do I turn wireless OFF?
Jessica
I’ve just started to use the Technicolor TG582n gateway that came with my new fibre installation.  I don’t use wireless so how do I turn it OFF so that it isn’t a security problem?
Fixes: 6
Re: How do I turn wireless OFF?
Press the WiFI button on the top of the router.  Cheesy
Fixes: 50
Long press and hold until the light goes out. Short press to turn it back on.
petecov44
You see I never knew that. I have been doing it via the control panel - nice one Smiley
Fixes: 6
The button is well hidden, I bet most people think it's just a light.
Fixes: 100
When you press a button and nothing happens you might assume that it does nothing.
You might not think to press and hold for a few seconds.
At my age it has become instinctive to try a press and hold if a press doesn't work.
Customer and Forum Moderator.
Fixes: 62
Reminds me of the boot release button in my car - I reported it as not working at the first service and was very nicely told that I needed to hold it in for several seconds  Embarrassed
Fixes: 100
Wait until you get to my age Jim Wink
Fixes: 62
You mean AGAIN don't you  Sad
