How do I reset PlusNet Broadband Speedtest to zero ?
Infinity
How do I reset the recommended speed tester to zero, about to change ISP to PN ?
http://www.mybroadbandspeed.co.uk/
Epyon
Re: How do I reset PlusNet Broadband Speedtest to zero ?
Delete browser cache?
Infinity
That's too drastic, I don't want to lose other items.
dick:quote
198kHz
Seasoned Pro
Fixes: 9
Delete mybroadbandspeed cookie(s).
Papyrus and Comic Sans walk into a bar. The bartender says, "Get out -- we don't serve your type."
pierre_pierre
alt the mybroad results are stored as a cookie, so if you are testing on several machines, you get a different list,  hence 4C, clear the cookie
Infinity
Quote from: 4C
I've already done that several  times, quitting app and browser, all to no avail....
It's also based on your IP address, so if you have a dynamic one it might be worth disconnecting and reconnecting to see if that makes a difference?
Infinity
My 6 results show as 4 different IP addresses.
dick:quote
jojopillo
Hi PlusComUK,
If you have a different IP address and have cleared the cookies the try a hard refresh (Ctrl+F5) incase you have a cache page stored.
JojoSmiley
Infinity
I'm on Apple Mac !
jim:quote
jojopillo
Quote from: PlusComUK
I'm on Apple Mac !
In that case it should be command+shift+R
Jojo Smiley
Infinity
Doesn't work with Camino !
I'll try it with my other browsers
jim:quote
