How do I increase my usage allowance?
- How do I increase my usage allowance?
03-03-2008 6:25 PM
Hope someone can help. Thank you.
Re: How do I increase my usage allowance?
03-03-2008 7:11 PM
For some reason the icon is in the Connection settings menu, which isn't the most logical of places to put it, to be brutally honest.
but to save you some time, here is the link to get you there -
https://portal.plus.net/products/upgrade/change_data_transfer.html
If I remember rightly, if you have the Check box marked, you will be on a "Pay as you go" type allowance which means you will be charged £1 per extra Gb or part therof unless you have a limit set in place.
I hope this helps.
Roger.
Forum Plod.
03-03-2008 7:34 PM
Are there any other possible workarounds?
Dan.
03-03-2008 7:42 PM
The only other thing I can think of is that if you upgraded from another product like PAYG or Broadband Plus or Premier, then the component hasn't been added in the upgrade.
R
03-03-2008 7:48 PM
You're right about my being upgraded though. I guess I'll have to raise a ticket to get it sorted.
Thanks very much for your help,
Dan.
03-03-2008 8:09 PM
03-03-2008 8:31 PM
As per the ticket on your account this upgrade hasn't been done yet, which is why you don't have the option. I'll change the account type for you now.
03-03-2008 8:36 PM
Hope that helps,
03-03-2008 8:59 PM
*Tips hat*
I'll ask Mark to give you that pay rise now
03-03-2008 9:30 PM
It turned out I was still on the old Broadband Plus account - shows what I know!
Thanks for the fast replies.
Dan.
