How do I increase my IP profile
- How do I increase my IP profile
15-08-2007 9:30 AM
Could someone tell me how (and if) I can increase my IP profile speed as I seem to be stuck at 2000kbps and would like it to be faster if possible.
Doing the BT speed test gave this result.
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 2000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 3712 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1755 kbps
I have tried reconnecting the router a few times but it doesn't seem to make a difference to the IP profile speed.
(My username on PlusNet is jrp99)
Jeff
Re: How do I increase my IP profile
15-08-2007 9:52 AM
It would also be worthwhile having a read of James' blog post for the quirks of MaxDSL.
15-08-2007 10:18 AM
15-08-2007 10:24 AM
The router is synching at 3712 as per the BT speed test.
It has been consistently at the speed for a while.
Jeff
15-08-2007 1:58 PM
I never get any disconnections either.
Is there a way to get the IP Profile to 3000 as per Peter's comment?
Jeff
15-08-2007 4:55 PM
Quote from: minkey The router is synching at 3712 as per the BT speed test.
Hi Jeff,
BT's line reports suggest that your sync drops to levels lower than that quite frequently (when you're asleep maybe?). The second column of speeds represent the sync speed when the event was recorded.
2000 12/08/2007 19:52:44 2272 12/08/2007 18:13:31
2000 12/08/2007 19:29:18 2848 07/08/2007 12:13:16
2500 07/08/2007 13:06:11 2848 07/08/2007 12:13:16
2500 07/08/2007 12:54:37 3424 06/08/2007 21:13:20
3000 07/08/2007 02:45:07 3424 06/08/2007 21:13:20
3000 07/08/2007 00:30:38 2272 26/07/2007 22:13:16
2000 26/07/2007 23:56:00 2272 26/07/2007 22:13:16
2000 24/07/2007 21:01:45 2272 24/07/2007 20:13:13
2000 24/07/2007 20:40:30 3424 23/07/2007 00:15:00
3000 24/07/2007 10:36:35 3424 23/07/2007 00:15:00
3000 24/07/2007 10:13:45 2272 21/07/2007 14:13:19
2000 21/07/2007 16:19:59 2272 21/07/2007 14:13:19
2000 20/07/2007 12:15:25 2272 20/07/2007 10:13:11
2000 19/07/2007 00:34:07 2272 18/07/2007 21:13:16
2000 18/07/2007 23:36:50 2848 16/07/2007 00:13:15
There only needs to be a brief drop for the profile to readjust.
15-08-2007 5:08 PM
1) Move the router to the BT Master socket.
2) Replace all MicroFilter's with high quality ones. Or a filter face plate on the master socket.
3) Google "ring wire removal" this is a mircual cure that can give a few extra dB's on the Signal Noise ratio. And hence more Mb's.
Chilly
15-08-2007 7:30 PM
15-08-2007 9:34 PM
That IP profile is about right for your sync speed.
15-08-2007 10:16 PM
from 7392Kbps -> 6.5Mbps
from 7968Kbps -> 7Mbps
from 8128Kbps -> 7.15Mbps
link.
