How do I get my IP profile to update
- How do I get my IP profile to update
02-08-2010 9:36 AM
After 5 days the IP profile still hadn't changed so I did a manual resync - it is now 4 days 17 hours later and the IP profile still hasn't changed.
Quote Download speedachieved during the test was - 2222 Kbps
For your connection, the acceptable range of speedsis 1000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :3776 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2742 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 13.81:23.33:62.85 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
This really isn't acceptable so what can Plusnet do about it.
Re: How do I get my IP profile to update
02-08-2010 10:22 AM
Hopefully I modified the noise margin before the exchange picked it up when reconnecting and am now back at 3,776kbps
02-08-2010 1:36 PM
Quote from: Oldjim ... so what can Plusnet do about it.
You of all people surely know the answer to this, Oldjim?
AFAIK under the right circumstances Plusnet can:
1) Ask for a stuck IP Profile to be unstuck
2) Ask for the DLM to be reset to training mode
Maybe (1) is actually the same as (2), I'm not sure.
02-08-2010 2:25 PM
Re (2) I may go for a retrain but not until I am sure everything is OK - need to wait for some heavy rain
General - If I had known I wouldn't have asked the question
02-08-2010 4:40 PM
General: Oldjim, you seem so knowledgeable in other areas of broadband faults I had presumed you would know about this also.
02-08-2010 4:43 PM
02-08-2010 5:01 PM
After the involuntary disconnection this morning as described above I will leave it for 4 days before bothering the faults team just to see if it has fixed itself
In view of the IP profile reported by the speedtest can you increase my Plusnet profile to 2742kbps to match
02-08-2010 5:07 PM
02-08-2010 5:09 PM
Graham
02-08-2010 5:11 PM
You can occasionally get a non-standard profile, I have no idea why.
02-08-2010 5:12 PM
Go ahead - it will be interesting to see if the IP profile is really 2742 and a speed test may confirm it
Quote from: Ben You can have 3Mbps
02-08-2010 5:28 PM
For your connection, the acceptable range of speeds is 1000-2742 Kbps.
Assured Rate IP profile on your line is - 2742 Kbps
Even less bothered about waiting for the profile to increase to 3000kbps unless of course it increases to another intermediate figure
