How do I get a dynamic I.P. Address ?
gunster
I'm on fibre but I don't know how to get a new IP, I have tried rebooting the router but my IP stays the same, can anyone advise please ?
Many thanks in advance.
Fixes: 62
Re: How do I get a dynamic I.P. Address ?
If you go to here is there an icon for static IP address https://portal.plus.net/my.html?action=myconnection
Plusnet Staff
Plusnet Staff
Fixes: 5
Is it a Static IP you're after (where your IP address always remains the same) or an IP that changes, dynamic as you've mentioned?
Is there a specific reason you wanted a new IP address?
Chris Pettitt
Cloud Environments Engineer
