How do I fix.
redbull2k14
How do I fix.
All games I join on COD Ghosts I am suffering with lag. How can I diagnose where the problem lies?
My set up is as follows. BTO Modem>PN Router>Sam-Knows White Box> PS3.
I have the ports forwarded, set the PN Router into game mode also set PS3 into DMZ assigned the PS3 static IP. UPnP is turned on.
I have Wireshark I can capture the packets.
any help?
sully72
Re: How do I fix.
disable upnp in the router and in the ps3....
redbull2k14
Re: How do I fix.
I will give that ago and let you know how it goes.
redbull2k14
Re: How do I fix.
I have discovered that my PN Router is faulty. I connected my PS3 to the WAN of the BTO Modem. My problems have gone. How do i go about getting a new Router off PN?
wo0x
Re: How do I fix.
Quote from: redbull2k14
I think they'll send you one if you pay £5.99 delivery, you can raise a ticket to request that. I also believe it will tie you in to a 12 month contract. I'm sure I'll be corrected if I'm wrong on any (or all) of that.
I would, however, recommend buying your own... Routers supplied by ISPs are junk in my experience.
ian007jen
Re: How do I fix.
There are reports of the Sam Knows box causing issues...people seem to be removing them to take them out of the equation.
Ian
Fixes: 162
Re: How do I fix.
If you've got the ports forwarded, you don't need the DMZ really. Can you try putting the router back to to factory defaults and trying to game without making any changes to it?
 Chris Parr
 Plusnet Staff
redbull2k14
Re: How do I fix.
I will give that a go.
TORPC
Re: How do I fix.
Quote from: ian007jen
<snip>
Ian
Have you got a link please Wink
redbull2k14
Re: How do I fix.
Before I connected directly to BTO Modem, i bypassed the SamKnows and connected to the PN Router same result.
redbull2k14
Re: How do I fix.
As instructed, reset PN Router changed no settings. Game play is still full of lag however it worked in my favor. Next test I changed a setting in PN Router and enabled game mode. Played some games, no change to game play. Backed out of lobby and noticed NAT type as STRICT. not sure why this has happened.
Here is a snippet of my event logs
these two were at 21:03 and 21:04
FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: ************ Dst ip: ********* Type: Destination Unreachable Code: Communication with Destination Host is Administratively Prohibited
FIREWALL icmp check (1 of 17): Protocol: ICMP Src ip: ************ Dst ip: ********* Type: Destination Unreachable Code: Communication with Destination Host is Administratively Prohibited
these two were at 00:15 and 00:24
FIREWALL icmp check (1 of 10): Protocol: ICMP Src ip: ************ Dst ip: ********* Type: Destination Unreachable Code: Communication with Destination Host is Administratively Prohibited
what next?
redbull2k14
Re: How do I fix.
I have had another go today. Before playing a game it tells me my NAT is STRICT, so i quit the game and check my network settings on the PS3, then test my settings, reports back that NAT type 2 and UPnP is available. I decide to load the game up and play a game it feels like before only this time the game reports STRICT.
So this is what im thinking even if i forward all the ports or put it in DMZ im always going to get the same result using this PN supplied router.
I reported a few week back that there was a power cut in my area. I believe this is the cause, maybe the manufactures need to look into the router when there is sudden power loss and comes right back on all with in 1 second which is what happened to me.
Are there any further test i can do to prove or disprove?
redbull2k14
Re: How do I fix.
just turned UPnP off in router and run network test on PS3 and said UPnP unavailable, loaded up my game and tells me my NAT is OPEN. I did not expect to see that, so i look in my event logs and see this
IDS fragment parser : fragment sweep (1 of 1) : 198.107.*.15* 212.*.66.* 680 45 UDP frag 50563:660@1480 not sure what that is all about maybe someone could enlighten me.
Now im going to play a game see what game play is like.
redbull2k14
Re: How do I fix.
can I have a new router sent to me please, the one i got is broken.
ghos7em1
Re: How do I fix.
if you are using the tg582n telnet into it and disable ids and firewall. telnet way is the only way to fully disable firewall.dont use upnp and dmz together.if you still lag open port 3075 for ghosts
