How do I find out if I'm still in minimum contract?
clairecable
I've been with plusnet since 2014 for phone and broadband. Having done some shopping around I've discovered that I can get my phone and broadband significantly cheaper with another provider and not only that it is fibre broadband too. Anyway through reading up on the plusnet website it says that you may incur costs if you change provider and you're still in a minimum term contract (or words to that effect). I can't find anywhere on my account that outlines if I am in a minimum term. It does say contracted in brackets after my product title/description. Hoping someone can help to save me the hassle of ringing plusnet?
SpendLessTime
Aspiring Hero
Fixes: 56
Re: How do I find out if I'm still in minimum contract?
AT https://www.plus.net/my.html?s=0&action=account_summary if you are in contract there will be a charge saying "Upon Cancellation" against your broadband contract whiich is not equal to zero.
clairecable
So it says £0.00 (upon cancellation) does this mean I shouldn't incur any charges if I do decide to leave?
SpendLessTime
Aspiring Hero
Fixes: 56
Yes, although if you go to a supplier like Sky who do not use BT Wholesale network then you pay a cancellation fee for the line being transfer away from BT Wholesale. It is £30 if I recall correctly
clairecable
That's great thanks. It's Vodafone I'm thinking of moving to so not sure if they use BT wholesale network?
clairecable
I believe they may be though. A lot cheaper for me so chances are I may make the move
Plusnet Staff
Plusnet Staff
Fixes: 116
More information on the cessation charge can be found:
https://www.plus.net/help/my-account/charges-for-removing-broadband/
If you would like to discuss renewing your contract I would recommend calling our customer options team on 0800 013 2632 (Selecting option 1, then option 2) with usually not much wait.
Open until 8pm tonight and back at 8am tomorrow.
I hope this helps
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
Plusnet Staff
Plusnet Staff
Fixes: 116
You can check whether a service provider has an LLU presence in the exchange at
https://www.samknows.com/broadband/exchange_search
An LLU presence would usually trigger the cessation charge, but it's probably worth calling the new provider and asking them.
 Plusnet Staff
