How do I create 2nd Email Address
hamilton36
Is it possible to have more than one email address on broadband and if so how do I create one please?
Thanks,
Alex
Fixes: 10
Re: How do I create 2nd Email Address
https://portal.plus.net/my.html?action=myemail
Manage my Mail
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Denzil
Youcan have as many email addresses as you like, in the form whatever@username.plus.com. The "whatever" can be, well, anything you like. If you have the catchall turned on anything sent to you in that form will arrive at your default mailbox. If you want to organise different addresses in different mailboxes the link jelv gives is the place to visit.
There is some good advice <a href="http://www.plus.net/support/email/mailboxes/">here</a> on how to set it up.
hamilton36
Thank you Denzil. I had a look but I don't see a way to have another email address with different user name.
Thanks anyway,
Alex
Fixes: 10
Are you wanting a different name after the @ ? If so could you explain why please and we could then make suggestions.
Nick_Russell
Quote from: hamilton36
... another email address with different user name.
You could always open another free dial up account and collect this email as well as your existing using a client such as Outlook or Outlook Express.
