How do I connect my iMac directly to BT Fibre Modem
NatTheGooner
Hi
As a temporary solution to my lack of a fibre router I would like to connect my iMac via ethernet to the BT modem (Plusnet chap Simon said it would work)
I tried quickly before I had to leave for work but couldn't sus it out.
My iMac was asking about DCHP or PPPoE and other info
any help would be great
thank you
Fixes: 50
Re: How do I connect my iMac directly to BT Fibre Modem
Set it for PPPoE with your PlusNet username and password. http://www.plus.net/support/broadband/hardware/broadband-connection-settings.shtml
Fixes: 62
NatTheGooner
Thanks very much
I think I put in plusnet.dsl  instead of plusdsl.net
it should work, then I can share my internet wirelessly from the iMac
brilliant!
NatTheGooner
Just wanted to say thanks for the help.
I didn't have a fibre router so I followed the set up given in the previous posts and connected my iMac directly to the BT Modem and I was back online. I then turned on wireless internet sharing on the iMac and I could get online with the iPad and Wii U.
It was a really big help last night so thanks again.
(got the correct router from Plusnet now so it all fine now)
