How do I change to Google DNS?
- How do I change to Google DNS?
26-06-2011 11:34 AM
Do I have to do this in the router or can I do it from the OS?
Message 1 of 4
(760 Views)
3 REPLIES 3
Re: How do I change to Google DNS?
26-06-2011 11:36 AM
Lets start with what router you are using or what OS are you using?
Edit... If you know what to do you can do It from either the router or your OS.
If life gives you lemons, make lemonade.
Message 2 of 4
(414 Views)
26-06-2011 11:47 AM
Quote from: reetpetite Do I have to do this in the router or can I do it from the OS?
Either is possible.
Message 3 of 4
(414 Views)
26-06-2011 2:30 PM
The procedure for the TG585v7 and v8 is explained in the Community Support Library article How to change the default DNS Servers in a Thomson Speedtouch Router.
David
Message 4 of 4
(414 Views)
