How do I change my MTU on my plusnet router?
- How do I change my MTU on my plusnet router?
Re: How do I change my MTU on my plusnet router?
31-01-2013 4:19 PM
Also have I got the worst version of the Thomson router then as I see theres one with a higher number...
Any tehnical people online that know why my wireless broadcast speed has dropped by half please? Also on the mtu issue as well.
31-01-2013 4:20 PM
Quote from: jelv ip iflist
I've not changed mine and it's 1500 so I see no reason why it should be necessary to change it.
I want it set to the Xbox Live recommend setting of 1364
31-01-2013 4:21 PM
Try changing the channels on your router and see which give the best speed.
31-01-2013 4:23 PM
Quote from: SuperSaiyan4 I want it set to the Xbox Live recommend setting of 1364
Why would you want to slow your connection down when used by anything other than the Xbox?
31-01-2013 4:36 PM
I play black ops 2 online and I want to reduce my MTU settings in fact I specifically have my own internet connection in my room solely for Xbox Live and this is what I want to do if that's ok with everyone?
Also I have never ever come across any router in all the years of setting up and configuring PC's and networks where a router decides to just half the speed of the wireless broadcast speed...This is not good at all.
If it was trying to default to a wireless G signal then it would be 54mbps not 65mbps, in the case that it has dropped by half something tells me there is something wrong here.
31-01-2013 4:37 PM
So is there no where in the router where I can manage the mtu?
31-01-2013 4:40 PM
The pn routers are notorious for poor wifi speed. There are multiple threads on here about them.
31-01-2013 4:41 PM
The router normally limits the speed if it detects another interfering wireless signal in the area. try using http://www.metageek.net/products/inssider/ to see what other signals are in the area, what channel they are on and switch the router to an empty channel.
31-01-2013 4:44 PM
Quote from: Hairy Just replace the router with your hh3, and all will be fine again. You can use your PN log in on the hh3.
Thank you.
I had an idea when I first got this router it was rather poor build etc and even more so when I saw the options available...
31-01-2013 4:45 PM
Quote from: SuperSaiyan4 Also that telnet doesn't work im using windows 8 pro 64bit.
It will if you bothered to make the effort to find out how to enable it. This was the first result when I Googled "windows 8 telnet": http://www.sysprobs.com/install-and-enable-telnet-in-windows-8-use-as-telnet-client
31-01-2013 4:47 PM
Quote from: Chris Unfortunately not, there is only so much that can be accessed within the interface so the more technical stuff is left for telnet access.
Thank you, I have now changed it to manual and set it to number 5 in the list now its back to 130mbps 🙂
31-01-2013 4:48 PM
Quote from: jelv
It will if you bothered to make the effort to find out how to enable it. This was the first when I Googled "windows 8 telnet": http://www.sysprobs.com/install-and-enable-telnet-in-windows-8-use-as-telnet-client
I have never needed to use Telnet and with the advancement of technology never needed to go in a dos prompt to change mtu settings *facepalm*
Although thank you for the information and if this is the only solution I will use it, again thanks for the assistance.
31-01-2013 4:48 PM
Quote Thank you, I have now changed it to manual and set it to number 5 in the list now its back to 130mbps 🙂
Good to hear!
31-01-2013 5:02 PM
Failing that ill either go back to the homehub 3 or do a direct Ethernet link to the xbox from router etc.
31-01-2013 5:07 PM
Which is probably why no-one went into it and came back with the answer. None of us use it.
