How can I monitor which PC on my network is using the bandwidth?
- How can I monitor which PC on my network is using ...
28-02-2012 11:42 AM
I see the summaries on PlusNet for my usage, but it's around 1Gb a day on some days. I don't know which of the family PCs is using it or when. Is there some way I can monitor bandwidth usage per PC?
('scuse me if this is in the wrong Forum slot - it's such a vast forum and I cannot find a related topic. ???)
Message 1 of 5
(1,393 Views)
4 REPLIES 4
Re: How can I monitor which PC on my network is using the bandwidth?
28-02-2012 12:04 PM
Install NetWorX on all the machines http://www.softperfect.com/products/networx/
Message 2 of 5
(576 Views)
28-02-2012 2:03 PM
Windows only?
Message 3 of 5
(576 Views)
28-02-2012 2:35 PM
Yes, I'm on Windows, and it looks as if the Spiceworks monitoring application must be installed on a Windows PC, although they say it monitors Windows, Mac, and Linux PCs. Many thanks - I'll give it a try.
http://<a target="_blank" href="http://www.authorgraphic.co.uk/">Authorgraphic Technical Authors / T...
Message 4 of 5
(576 Views)
28-02-2012 3:07 PM
Hey guys,
you have to watch the artificially inserted Google? ads on their web site: I downloaded something totally other (Spiceworks) instead of NetWorx.
[And NetWorx, you need a MUCH clearer download link so that thousands of others don't download Spiceworks instead! :-X]
Message 5 of 5
(576 Views)
