How can I connect my phone to the wireless?
- How can I connect my phone to the wireless?
02-09-2011 9:54 AM
I have a Nokia xpress music phone and have previously been able to connect to my wireless at my family home, and around town e.g Mcdonalds, but when I try to connect to my Plusnet it won't work, saying the password is invalid sometimes and other times just wont connect.
Is it actually possible?
Message 1 of 4
(855 Views)
3 REPLIES 3
Re: How can I connect my phone to the wireless?
02-09-2011 10:25 AM
As long as you're within reasonable range of the router it should work just fine.
Re the password being incorrect, that can only ever happen for one of two reasons, the first and most obvious is a wrong password the other is having the wrong type of wireless encryption set, WEP and WPA are the most common options, our routers use the latter which is more secure anyway.
So I'd advise checking those settings on your phone first, if not then I'd advise logging into the router's settings page, making sure you have WPA set, then changing the pass key(not forgetting to update the pass key on your phone too.
Message 2 of 4
(534 Views)
02-09-2011 11:20 AM
How would I go about getting onto the router settings page?
Message 3 of 4
(534 Views)
02-09-2011 12:03 PM
We've got a support page to show you how: http://www.plus.net/support/broadband/hardware/thomson-585-faqs-and-troubleshooting.shtml
Message 4 of 4
(534 Views)
