How are these line stats?
- How are these line stats?
10-03-2014 7:23 PM
Link Information
Uptime: 1 day, 4:46:37
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1.022 / 17.751
Data Transferred (Sent/Received) [GB/GB]: 1,99 / 1,99
Output Power (Up/Down) [dBm]: 12,2 / 20,8
Line Attenuation (Up/Down) [dB]: 6,1 / 13,0
SN Margin (Up/Down) [dB]: 4,8 / 3,1
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 16 / 1
FEC Errors (Up/Down): 2.449 / 18.093.005
CRC Errors (Up/Down): 4.305 / 3
HEC Errors (Up/Down): 2.939 / 1
Re: How are these line stats?
10-03-2014 7:34 PM
10-03-2014 7:35 PM
10-03-2014 7:41 PM
10-03-2014 7:46 PM
10-03-2014 8:09 PM
I have had the connection for 3 or 4 weeks. I think that the training period is over?
The router is plugged into the master socket.
11-03-2014 9:47 AM
Thanks again
Gaz
11-03-2014 12:49 PM
Your SNR is low at 3.1db so there would be no benefit in resetting your line. I think the speeds look fine.
11-03-2014 1:38 PM
dick:quote
11-03-2014 2:11 PM
We can take a more detailed look at your line but the likelihood of you getting an increase in speeds is quite low since the only changed would could make would be to your SNR Target which is already set at it's lowest. It could be that a pair change would be required to get that increase in speeds, however, BT are unlikely to swap it over.
11-03-2014 2:52 PM
Cheers for the info!
dick:quote
