How To Open NAT
- How To Open NAT
How To Open NAT
How To Open NAT
04-08-2013 3:34 PM
Just wondering if someone could help, I've tried a number of different things to open my NAT as all the Online games I play regard my NAT as being Strict.
Now I'm getting FTTC installed on Thursday thus will be using the Fibre router supplied by Plusnet, I'd assume when I change to that my NAT should be open, If not how do I go about fixing this as it's causing problems in games such as Call of Duty.
Thanks in Advance, Richard.
How To Open NAT
How To Open NAT
04-08-2013 3:37 PM
Just wondering how I go about opening my NAT as It's causing problems in some online games. Now I'm getting FTTC installed on Thursday so I'd assume my NAT may be better when I switch to the Fibre router supplied by Plusnet, but if not how do I go about fixing this. I have tried a number of different things but no fix so far.
Thanks in advance. Richard.
Re: How To Open NAT
Re: How To Open NAT
04-08-2013 4:10 PM
Re: How To Open NAT
Re: How To Open NAT
04-08-2013 4:19 PM
Customer and Forum Moderator.
Re: How To Open NAT
Re: How To Open NAT
04-08-2013 4:34 PM
Re: How To Open NAT
Re: How To Open NAT
04-08-2013 5:43 PM
Also in the routers network settings, tick "always use the same IP address" for the console.
Re: How To Open NAT
Re: How To Open NAT
04-08-2013 6:47 PM
Disabling upnp and port forwarding doesn't work
Using just upnp again doesn't work
So I am left with using DMZ until I can replace the router with something better
Re: How To Open NAT
Re: How To Open NAT
04-08-2013 7:02 PM
Quote from: Gus
Did you tick "always use the same IP address" for the console?
That does appear to help with port forward and UPnP issues.
Re: How To Open NAT
Re: How To Open NAT
04-08-2013 7:13 PM
Re: How To Open NAT
Re: How To Open NAT
04-08-2013 7:25 PM
Re: How To Open NAT
Re: How To Open NAT
04-08-2013 9:16 PM
Tempted to upgrade to this router http://www.amazon.co.uk/Netgear-N900-Wireless-Gigabit-Router/dp/B005UGRF16/ref=sr_1_1?ie=UTF8&qid=13...;
rather than the one PN supplied with the FTTC
