How To Change DNS Settings On The Fibre Router?
RedOnRed
Does anyone please know hot to change the DNS settings on the Plusnet Technicolor fibre router?
Fixes: 61
Re: How To Change DNS Settings On The Fibre Router?
RedOnRed
Many thanks for that but none of the commands seem to enable me to remove the existing DNS entries. I can only add and remove new ones.
Are you still connected while trying to remove existing (in-use) entries?
Call me 'w23'
Fixes: 61
Removing the auto generated ones isn't possible I believe
You need to add the extra ones with a higher metric
Higher or lower (numerically) Jim?
You're probably correct - it's over 2 years since I had to telnet into my old 585V8.
Call me 'w23'
Fixes: 61
it is stated in the linked article - 10 is default so a number less than that has higher priority
RedOnRed
Quote from: w23
Yes, I have been. Hmmm, I wonder if connectivity locks them. It would make sense I suppose.
Edit: But  having said that I have to be connected in order to remove them.
Fixes: 61
connected to the router but the router isn't connected to the internet
RedOnRed
Oh I see.
Yes, the router was connected to the internet.
I've added the two DNS entries that I wanted all OK and that seems to be working fine with the metric priority set as 2. So as it stands things are now sorted thanks very much to your link and info.
The Plusnet router replaces my identical o2 one, but I have to say that although the o2 one followed a similar Telnet process it was a lot easier to apply.
dick:quote
Fixes: 35
Good stuff, I'll keep this in mind for when my fibre gets installed next week Smiley
 Adam Walker
plusmore
I am just in the process of migrating to PN from O2 - is there any reason to use another DNS in lace of the default? I use OpenDNS at the moment - is the PN DNS slow?
Fixes: 5
It's much slower than O2's DNS but I believe more reliable.
The following shows two methods to change the DNS resolver in the router.
http://npr.me.uk/changedns.html
