House re-wre
- Re: House re-wre
House re-wre
30-08-2013 1:21 PM
Starting on Monday (2nd Sept) the electricians are going to completewly rewire my house. This obviously means that during the next 10 - 14 days the power (& hence my modem & router) are likely to be off an on intermittently. Can anyone give me an idea of what this will do the my IPProfile ( I'm assuming it will get trashed?), and what, if anything I can do to get it back afterwards to the 53/13 I'm currently getting.
thanks
Neil
thanks
Neil
Message 1 of 6
(1,227 Views)
5 REPLIES 5
Re: House re-wre
30-08-2013 1:53 PM
Are you near enough to (and on good terms with) a neighbour who would let you run the modem and router off an extension lead?
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 2 of 6
(544 Views)
Re: House re-wre
30-08-2013 4:45 PM
Couldn't you just turn it off for the duration? If the powers going to be on and off constantly you're presumably not going to be using it?
Message 3 of 6
(544 Views)
Re: House re-wre
31-08-2013 4:35 PM
The kit will be on/off intermittently - I was just wondering what the DLM would make of it?
Message 4 of 6
(544 Views)
Re: House re-wre
31-08-2013 7:35 PM
Avoid too much on/off if possible, if switching off disconnect first via the router interface (if you know it's about to be switched off).
Call me 'w23'
Message 5 of 6
(544 Views)
Re: House re-wre
02-09-2013 1:11 PM
As W23 says, if you make sure to disconnect via the router's interface prior to turning it off you should be fine as that way it won't be picked up by the DLM system as a possible fault.
Message 6 of 6
(544 Views)
