House move x2
- House move x2
Re: House move x2
16-04-2009 7:15 AM
Quote from: Mav
Quote from: Anotherone you didn't comment about wiring.
Sorry, the router is connected direct into the master (socket through a filter) which was installed by BT on Tuesday. In fact, because it's a second line, they installed a double socket using the four wires already into the original master. The house is relatively new (7 years). The s/n has increased to 7dB..................................................
Any chance of a picture of this animal?
Does your parents' master socket have any extension wiring? Do they have a Cordless phone?
Something happened on the 3rd April to up your noise levels.
Re: House move x2
22-04-2009 10:37 PM
Up till yesterday not much had changed with s/n reducing from around 10/11dB in the day to 5.5/6 in evening. Without rebooting I would re-sync as low as 37xx in evening and high as 44xx during the days and my profile reduced to 3000.
Yesterday I lost internet while asleep and got it back this evening syncing at 5155 down and 888 up so it seems I am now on the 21CN trial - I do hope this doesn't complicate things further. I was only able to re-connect his evening by re-entering the Username and Password into the router. There is no way I deleted them and no-one esle here as access - strange, though, that the Remember option was still ticked.
I hope to have the photos of the BT socket done tomorrow and will post them as soon as. I have moved the router away from the TV and surround system FE unit - but only did that this afternoon.
I'm concerened about the amount of errors reported after just 3 hours:
Quote FEC Errors (Up/Down): 4,294,967,264 / 1,554,089
CRC Errors (Up/Down): 4,294,967,264 / 88
HEC Errors (Up/Down): 0 / 81
Att is now 44.5dB and s/n is 4.5dB.
I realise I have to wait yet another 10 days for the 'training' period and will refrain from rebooting - unless, of course, it becomes necessary.
Thanks for all the continued support
Edit: My parent's Master socket as mentioned above is on the same faceplate as mine. They do have an extension in the master bedroom and the 'office' upstairs. These extensions were added when the property was built around 8 years ago. They have a cordless phone connected to the master socket by an extension cable and normal phones upstairs. Each phone has a splitter connected. Not sure how my parent's broadband or connected phones could affect my connection but am willing to undergo any tests to keep a stable high sync where possible
Forum Moderator and Customer
Re: House move x2
23-04-2009 9:07 AM
The username/password issue could be because of the mode change. Unless you did a powerdown of the modem/router before syncing on ADSL2+, I'd just put those enormous error figures down to the loss of sync whilst the changeover took place - providing they don't re-occur.
When it's convenient, powerdown the modem/router (even for several hours). Powerup at a suitable time, I'd suggest when noise levels have likely gone to about 6-7 dB, only because we don't know how much lower it may go and if the modem/router will hang on and what the error rates may do.
Re: House move x2
23-04-2009 11:55 AM
Quote from: Anotherone Any chance of a picture of this animal?
Here are three photos of the 'animal'
My BB is the left hand connection. Both my parents and I have filters directly into our reespective sockets. Do any of these help at all?
My apologies for the poor quality but my camera is packed away somewhere so have relied on the mobile phone's
Can't hear any hum.
I did press the rest button when I found I was unable to connect any other way - I doubt that should have wiped the username/pw, though?
What if I power down the router whenI go to bed - probably around 3/4 am and power up again around 9/10 in the morning?
Re: House move x2
23-04-2009 1:14 PM
Re: House move x2
23-04-2009 1:31 PM
But, surely, moving the filter by way of a short extension lead would not make any difference considering the faceplate is right next to a row (all 4 used) of mains sockets?
Re: House move x2
23-04-2009 1:45 PM
For several reasons (not picture quality - that's OK).
First re last comment. No extension lead on the filter What's that brick running anyway. If it's the modem/router I can't see it making any difference BUT as it's unshielded no doubt, but the output will be fltered (I would hope) you could try the brick further away to see if it makes any difference.
Going for caffiene top up, back in a mo.
Re: House move x2
23-04-2009 4:35 PM
Bellwire on your parent's line, not likely to have much effect on a fixed 2M connection but never the less still act as a nice aerial and interference could be coupled into your line. I'd disconnect that at the master and all extensions. But see next.
I see that's a Plug-splitter microfilter on your parents' line. If it's one of the older nasty types it may feed the bellwire through rather than create its own. So if used elsewhere, you need to check that the phone still rings after you've disconnected the bell wire (should be ok at the master). The phone may not need the bell wire anyway. If it doesn't ring, try one of your filters and use the thing somewhere else on your parents' line that doesn't need a bell wire/phone.
As for looking for sources of noise, don't forget to try switching off all cordless phones and base stations and unplugging from the lines to see if that affects the noise levels.
Edit: As for powering up the router well that's up to you, you may want to wait turning it off until you've had a go at reducing the noise. The only reason I said about 6-7db is that it shouldn't cause any massive change in sync speed, which may leads to drops if the noise margin then goes too low. But if you manage to reduce some of the noise, the time when the margin is 6-7db may change and in any event with reduced noise you should get a better sync speed (this assumes that you have a Target SNRM of 6dB).
Re: House move x2
23-04-2009 8:34 PM
Quote from: Anotherone As that double master isn't any form of NTE5 variant, is that incoming cable joined to the drop or u/g cable at one of those new external NTEs.
I have no idea what the new external NTEs are or look like It's dark now so I'll pop outside tomorrow and see what's on the other side of the wall.
The spliiter by my parent's master socket is quite old, I think, as is the one in the bedroom. The office one is what came with the Sky router. I'll get the others changed to two, reasonably, new ones tomorrow. Will also disconnect the bell wire - which colour and/or connector will the bell wire be?
I have turned off cordless phones previously (I have one in my room by the PC and my parents have one in the living room) with no effect.
The router resynced about 17 mins ago to 888 / 5,312. This probably coincided with the streetlights turning on although I can't see any from my window.
The Att went to 45dB and s/n to 6dB
Around 5 mins after I refreshed and the Up errors have increased dramatically again:
Quote Error Seconds (Local/Remote): 18 / 0
FEC Errors (Up/Down): 4,294,967,264 / 29,297
CRC Errors (Up/Down): 4,294,967,264 / 12
HEC Errors (Up/Down): 0 / 9
I was reading up on the Thomson and wondered: should the DSL Type be set to G.992.5? It's currently set to G.992.3 annex A. If so, how do I make this change?
Re: House move x2
24-04-2009 12:53 AM
Re: House move x2
24-04-2009 4:39 PM
Below is a photo of the box outside where the BT cable enters - is that any help?
Unfortunately, to be able to change the filters on all (3) my parent's extensions along with removing the bell wire will have to wait till my better half returns in 3 weeks as there is a lot of heavy furniture to be moved
Will it hurt to leave things that long?
The 'brick' next to the splitter is for the router.
Meanwhile the Att is staying at 45dB and the s/n has increased to 7dB and I am syncing at 888 up and 5166 down - last re-sync was 19.5 hours ago.
The number of errors remains high:
Quote FEC Errors (Up/Down): 4,294,967,264 / 11,289,520
CRC Errors (Up/Down): 4,294,967,264 / 272
HEC Errors (Up/Down): 0 / 222
Thanks for the continued support
Re: House move x2
24-04-2009 8:34 PM
Re: House move x2
25-04-2009 5:15 AM
Being slightly more serious do you have a known good router you can try? I'm beginning to suspect that this 585 maybe faulty.
The bell wire is the orange one on terminal 3, which socket is their phone plugged into?
Did the BT engineer have that grey covering off outside? I'm guessing there must be another connection inside somewhere.
Re: House move x2
27-04-2009 12:43 PM
Quote DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 888 / 5,643
Att has gone up, though:
Quote (Up/Down) [dB]: 25.5 / 48.5
SN Margin (Up/Down) [dB]: 10.0 / 7.0
Up errors have stayed low for the last three hours:
Quote FEC Errors (Up/Down): 0 / 18,434,868
CRC Errors (Up/Down): 0 / 123
HEC Errors (Up/Down): 0 / 101
BT test showed my profile has risen to 4500
Quote Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 5643 kbps(DOWN-STREAM), 888 kbps(UP-STREAM)
IP profile for your line is - 4500 kbps
Actual IP throughput achieved during the test was - 2610 kbps
I'm not sure I could squeeze any more out of this. Still have some further checks to make as requested by Anotherone when SWMBO comes home. But, if this connection remains stable then maybe best left alone
Meanwhile, my speed is restricted to 3000 due to my PN profile. Could someone kindly give it a kick, please
Edit: Added BT test result.
Re: House move x2
28-04-2009 3:45 AM
Things seem stable so far. Still syncing at 888 / 5643 with att of 48.5 and s/n at 4.5. This is good news now, yes?
No more up errors but just over 70,000,000 DL FEC errors (18.5 hours). Is that acceptable? Does it indicate a potential problem somewhere?
Still a little concerned that my profile at PN hasn't yet risen to match the BT profile of 4500
