House move question
- House move question
House move question
04-06-2009 5:32 PM
I feel like I'm going to have to take a backwards step. I've kept on the legacy products in order to maintain speed and reliability but now it would seem there's not much point or can anyone tell me differently?
Re: House move question
04-06-2009 6:36 PM
04-06-2009 6:38 PM
I think its a close snap
04-06-2009 6:45 PM
04-06-2009 7:03 PM
BT ADSL broadband availability
You are connected to the Crownhill telephone exchange.
ADSL is available in your area
Your exchange is also enabled for ADSL Max services
According to BT Wholesale, your phone line should be able to support a 1Mbps or greater ADSL connection.
Standard ADSL RAG results
You cannot receive 2Mbps ADSL
You may be able to receive 1Mbps ADSL
You may be able to receive 512kbps ADSL
(Engineer visit likely)
You may be able to receive 256kbps ADSL
You are approximately 2.92km from the exchange. Note that this is the straight line distance - the actual cable length will be longer!
and....
BT 21st Century Network (21CN) rollout
Wholesale Broadband Connect is available in your area
There is currently no 21CN migration date for your PSTN service
....I must admit that I'm finding this very confusing. I don't know what ADSL RAG is and whether I need it but it says I can't get 2Mbps. Do I take it that because it says ADSL Max, then this is the faster speeds? Sorry to be so thick. My brain has gone fuzzy - house move is tomorrow.
04-06-2009 7:47 PM
05-06-2009 12:02 AM
Quote from: Annie ....I must admit that I'm finding this very confusing. I don't know what ADSL RAG is and whether I need it but it says I can't get 2Mbps. Do I take it that because it says ADSL Max, then this is the faster speeds? Sorry to be so thick. My brain has gone fuzzy - house move is tomorrow.
RAG is an acronym for Red Amber Green I believe. It was originally used with the fixed rate products to determine whether or not BT would provision a customer at a certain speed.
Given the results from the database checks you've done you're probably looking at around 2Mbps even on Max. In all fairness though, you're not really going to know for sure until you get your kit plugged in at the new address and are able to check your line stats.
11-06-2009 6:10 PM
http://www.mybroadbandspeed.co.uk
Today 17:37 1722 kbps (215kB/s) 382 kbps (47.8kB/s)
Jun 4, 17:26 6722 kbps (840kB/s) 363 kbps (45.4kB/s)
http://speedtester.bt.com
Today
Your DSL connection rate: 1472 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 2000 kbps
Actual IP throughput achieved during the test was - 1205 kbps
Firstly, is there anything that can be done about the speed? It feels like quite a backwards step. I lived at this house before, 4 years ago and nothing has progressed since, it would seem.
Secondly, I am on a legacy product - PlusNet Broadband Your Way Option 2 with included 15GB bandwidth - I stayed on this product because performance was important to me. I'm not a particularly heavy user - mainly email and surfing. In the past, I have looked at the charts about how traffic is prioritized but I must admit, I get a bit confused. Am I getting anything better staying on Option 2 than I would get if I moved to a newer product?
There are two more factors to take into account. I intend to start using the VOIP phone soon so the 2 hours of free calls will be useful. I also make use of the fax2email facility and I'm not sure whether I can keep these if I change products.
11-06-2009 6:37 PM
It sounds like you're further from the exchange than you used to be. Unfortunately, there's not too much we can do about that until we're able to offer a fibre service.
Regarding the new products - It depends on what you use the internet for. If you're just talking about web browsing, email and some streaming, Value is probably about right!
11-06-2009 6:51 PM
Quote from: Annie There are two more factors to take into account. I intend to start using the VOIP phone soon so the 2 hours of free calls will be useful. I also make use of the fax2email facility and I'm not sure whether I can keep these if I change products.
Hi Annie,
You can keep your 'extras' if you moved on to the newer products as an existing customer.
I kept my VoIP minutes when I moved from Premier to Unlimited as well as my webspace.
11-06-2009 6:58 PM
11-06-2009 7:04 PM
I think they are kept my default if you switch product, but that might need to be confirmed.
11-06-2009 7:32 PM
Also Crownhill is a Market 3 exchange so the cost for value would be £5.99 per month with 10G traffic
11-06-2009 7:36 PM
11-06-2009 7:39 PM
