Honest opinions please
- Honest opinions please
- « Previous
- 1
- 2
- Next »
Re: Honest opinions please
25-06-2013 10:54 PM
Message 16 of 22
(578 Views)
26-06-2013 9:07 AM
Message 17 of 22
(578 Views)
26-06-2013 9:23 AM
why thank you, just need to wait for payday next week to sort, then hopefully can start the ball rolling and come back into the plusnet fold lol
Just want to check a couple of things, the first month payment is that right that is it due straight away or is it when plusnet take over the line?
and the supplied router, how good is it really, most of my connections are wired, ie pc, ps3, sky box etc, but i do have a tablet which i use round house, and my daughter has a pc attached wirelessly in the room above where the router is?
im only using the standard supplied sky router anyway not the sky hub , and that works fine so will it be as good as that?
i read the bt home hubs work- is that true?
dick:quote
dick:quote
Message 18 of 22
(578 Views)
26-06-2013 1:03 PM
Hi Orico, I'll do my best to answer.
It's taken straight away, but we don't start counting the first month until both the service and your account are activated. Basically that means that while you do pay the first month up front, you won't pay for the second month until the service has been working for a full month
There's differing reports. Most people have no issues, but it depends on how thick the walls/floor are among other things. You should be fine but if there are any issues we'd be more than happy to look into them for you.
Well, we supply the TG582n - not sure what Sky are sending (used to be a Netgear if I remember correctly) so there may be differences unless it's the same model.
Yes, they do
Hope that helps.
Quote from: orico Just want to check a couple of things, the first month payment is that right that is it due straight away or is it when plusnet take over the line?
Quote from: orico and the supplied router, how good is it really, most of my connections are wired, ie pc, ps3, sky box etc, but i do have a tablet which i use round house, and my daughter has a pc attached wirelessly in the room above where the router is?
Quote from: orico im only using the standard supplied sky router anyway not the sky hub , and that works fine so will it be as good as that?
Quote from: orico i read the bt home hubs work- is that true?
Yes, they do
Hope that helps.
Message 19 of 22
(578 Views)
26-06-2013 2:14 PM
Thanks alot, that is really helpful, yeah the sky is an old netgear dg934g router, not bad to be honest
pretty set to sort soon lol, one more question sorry lol
the bt homehub looks good to get though, not bad prices on ebay, is it the homehub 3 i would need to buy? and there are type a and b versions, does that matter
Message 20 of 22
(578 Views)
26-06-2013 2:17 PM
You might find the Community Support Library article Using a BT Homehub 3 or 2 on Plusnet ADSL or FTTC of interest.
That covers which model to go for.
David
Message 21 of 22
(578 Views)
26-06-2013 2:28 PM
Thats great, thanks alot
dick:quote
dick:quote
Message 22 of 22
(578 Views)
- « Previous
- 1
- 2
- Next »
