Homeplug/router settings
stubbs307
Because my Technocolour wireless router is some distance from the PC, the signal strength was "poor". I have bought a pair of Devolo AV500 homeplugs to rectify the problem. Connecting them has been very straight forward, and everything is as stated in the setup guide, however my windows 7 PC is still showing me connected wirelessly.
Is everything OK - or am I doing something wrong!
Any advise would be very gratefuly received. Undecided
rovingeyeuk
Re: Homeplug/router settings
Hi, if you go into your network settings you can disconnect the wireless and the wired connection should be left running.
Right click on the network icon to open it up and the settings information is there. I use Solwise home plugs and this happens on both the desktop and laptop.
Hope this helps.
stubbs307
I did as you suggested, and it works just fine.
Thank you for your help Smiley
