Home Hub 5 just disconnected itself and reboot twice
- Re: Home Hub 5 just disconnected itself and reboot...
23-01-2014 2:20 PM
Accompanied by the following logs:
14:04:08, 23 Jan. ( 15.410000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
14:03:26, 23 Jan. ( 3627.460000) PPP LCP Send Termination Request [User request]
14:03:25, 23 Jan. ( 3625.820000) The system is going DOWN for reboot.
14:03:25, 23 Jan. ( 3625.820000) OpenRG is going for reboot by IPC command
14:03:20, 23 Jan. ( 3620.820000) OpenRG will go down for reboot in 5 seconds
So it looks like it was rebooted under remote control from something (perhaps the cab?)
Anyone know what the mechanism is here? Should I be concerned?
Re: Home Hub 5 just disconnected itself and reboot twice
23-01-2014 2:39 PM
11:47:22, 23 Jan. (1036840.080000) CWMP: Download file, FileType=4, FileName=5a-1.7-testpackage-package.tar.gz.aes.rsa.signed, Username=, CommandKey=1329156652
Not sure I like this "router with a mind of someone else's" malarky...
23-01-2014 5:49 PM
26-01-2014 9:03 PM
26-01-2014 9:55 PM
26-01-2014 10:02 PM
26-01-2014 10:37 PM
27-01-2014 8:46 AM
27-01-2014 2:12 PM
04-02-2014 4:57 PM
and the linked article on the bt care systems mirrors the error you pasted below..
https://community.bt.com/t5/BT-Infinity-Speed-Connection/PPP-LCP-Send-Termination-Request-User-reque...
Worth keeping an eye on.
05-02-2014 11:25 AM
There is a retail version of the HH4 known as the Home Hub 4r which is an unmanaged device. It can be bought from Dabs etc.
http://www.dabs.com/products/bt-home-hub-4r-94XH.html
Graham
05-02-2014 10:18 PM
Im guessing the issue is with the firmware on the homehub 5 ....hopefully update will come soon if BT are looking into this issue ...then can remove openrreach modem
06-02-2014 4:18 PM
Yes the home hubs get updates from BT despite being on PN. I had a HH2 and it always got the updates, and I have just swapped for HH5 which has updated.
Re: blocking these updates - well I am not sure everyone would want this - so if you do find a way of doing it you need to ensure it can be selectively applied.
Regards, David
06-02-2014 8:04 PM
Quote from: karlos103 Today i have unlocked my openreach modem and connected it to my hh5 ...so now hh5 acts as router only ....
Seems the best way to keep the dreaded dlm at bay until this issue is sorted...
( OR modem doesn't need to unlocked -just spare if other people are not confident at unlocking- although unlocked ones are always useful)
06-02-2014 10:37 PM
